Old 10-21-2015, 08:20 PM   #1
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
E85
i have a question for you e85 guys. any one having injector plugging issues? or having them regularly cleaned?
the reason i ask is im going to be wanting to run e85 in my new build but my buddy has a 1600+hp jet boat on e85 and has to regularly clean his injectors due to clogging. about every other race weekend he has to pull them and have them cleaned. im not gonna want to run e85 if that is gonna be a problem for me. i know e85 is a magnet to water and being that its a jet boat that on the water if that could be his reasoning for it or not.
any input would help. will be around 900 to 1000rwhp TT build with e85.
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
Old 10-21-2015, 10:36 PM   #2
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
There's a thread on TurboBuick.com that talks about e85 clogging injectors. It almost gave me the impression that the problem is regional. Some talk about adding something or other to stabilize it and prevent injector gumming(I can't find the thread ATM).
I personally have ran e85 through my Grand National's injectors for years and let them sit for months on end w/o running and never had a problem.
The brand new FIC 2150's that I just put in the Camaro recommend running gasoline like every 5th tankful of e85. The FAST 95's that I just took out, ran on e85 for 2+ years w/o a problem (occasionally gas).
My motor is down for right now. But on my single turbo, it seemed to love .66 lambda. When running that rich at WOT, you can pretty much watch the fuel gauge drop.
Jack Bilger
granatl is offline   Reply With Quote
Old 10-21-2015, 11:50 PM   #3
SilverSS1LE
yeah i havent come across anyone here saying or complaining about them clogging. but i also will probably be running the flex sensor to be able to run gas/e85 so i could run a tank of gasoline through which i know would help clean the injector. i just dont want to jump into e85 if its a problem with injectors.
Old 10-22-2015, 12:04 AM   #4
Unreal
Drives: 2006 Z06
Need e85 compatible parts. Some injectors, and some fuel lines will gum up.
Nick
Corvette Z06 -1200ish rwhp
Old 10-22-2015, 12:43 AM   #5
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
This was actually something I was wondering about as well as I'm going to do a flex fuel kit along with zl1 injectors, fuel pump and adm fpcm in about a month. Good to know that the injectors wont get clogged.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 10-22-2015, 01:08 AM   #6
SilverSS1LE
all of his stuff is e85 compatible and it still gums up the injectors.
Old 10-22-2015, 09:13 AM   #7
Unreal
Drives: 2006 Z06
Then he either doesn't really have e85 parts, or is getting bad e85.
Nick
Old 10-22-2015, 09:30 AM   #8
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Would an Inline fuel filter help with this?
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-22-2015, 10:21 AM   #9
Unreal
Drives: 2006 Z06
No, it is more a reaction with the parts, so if you have injectors like ID2000s that gum up because the internals are not SS, a filter doesn't help.
Nick
Old 10-22-2015, 11:36 AM   #10
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
Bam ^
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 10-23-2015, 04:12 AM   #11
SilverSS1LE
all of his stuff is stated to be e85 compatible and weve tested his e85 and he is been getting above e85, normally close to e90 or so. and he run stainless inline filters after pump and runs all stainless tubing for fuel.
so back to the question, if i run stuff stated for e85 it shouldnt gum up?
Old 10-23-2015, 06:13 PM   #12
SilverSS1LE
so after doing some research and talking to injector dynamics they referred me to this article. http://injectordynamics.com/articles/e85/
so from the article facts its the injectors that rust up with the water that gets in the e85 fuel as a result of it being hygroscopic. so its really inevitable if the car sits up for any amount of time with fuel in it.
Old 10-23-2015, 06:55 PM   #13
Unreal
Drives: 2006 Z06
Unless you run a SS internal injector like I said, that won't gum up. ID 1300s, ID1700s, etc.
Nick
Old 10-24-2015, 09:28 PM   #14
SilverSS1LE
okay like i said he is running SS internal injectors and still has gum. the e85 isnt bad every fuel jug is checked before putting in tank. so now where is it coming from?
