Old 10-23-2015, 04:50 PM   #1
William.23
William.23's Avatar
Drives: 2011 Summit White.
Front 12v Port
Hi guys, so I never used the 12v Port (Top right of the shifter). I can recall I've used it maybe...4 times and it has worked.
Now it doesn't. I noticed that there is a little circular gold ring missing inside of this port. Because the other port inside the arm rest, has a circular gold ring and it works perfectly.
Anyone know if there's a part # I can buy or something I can use to make it work?
Remember : It's only a gold little circular ring missing *I'm sure it's what gives the current*. The Gold circular thing is inside the port that is located under the armrest, and works PERFECT.
Thanks guys!
William.23 is offline   Reply With Quote
Old 10-25-2015, 11:42 AM   #2
jwhutton52
jwhutton52's Avatar
Drives: 2014 Camaro 2SS / RS Coupe
Sounds like one of the connectors pulled out. You'll probably have to replace the entire unit unless you figure out what happen to the piece.
jwhutton52 is offline   Reply With Quote
Old 10-29-2015, 06:43 PM   #3
William.23
William.23's Avatar
How would I come about replacing the entire unit ? Is there part #'s for this?
I want to avoid going to my Chevy dealership as much as possible. They are crooks and very unethical.
THANKS!
Old 10-29-2015, 08:33 PM   #4
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
THANKS!
This is the part number 92230851. You google gm parts and enter the part number for their price.
Here is one site.
http://www.cheapestgmparts.com/chevr...e=power-outlet
Caddy
Caddyroger is offline   Reply With Quote
Old 10-30-2015, 09:28 PM   #5
William.23
William.23's Avatar
Here is one site.
Thank you Caddy! You're a lifesaver !
Going to order and see how it goes. Not quite sure how to install it but should be pretty straight forward.
Thanks again!
Old 11-03-2015, 11:44 PM   #6
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
The socket is in 2 parts. You have to put the ring on the body separately, after attaching under the cover. If you try to mount it to the cover as 1 finished piece you will destroy it.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Laminator FX + Extendolator • SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
