10-24-2015, 05:01 AM | #1 |
Drives: 2010 camaro SS Join Date: Jun 2014
Weld racing wheels questiin
I'm currently in search of a set of weld racing wheels but I am new to the dimensions of drag set ups. I am looking for a set of 17 or 18" wheels, but I daily drive my camaro so I'm looking for a size for the front wheels so that I can run a regular street tire not a skinny. What dimensions should I be in search for? Thanks
2010 CGM 2SS
Blackwing SLP CAI TSP 2" LT headers 1.25 pfadt lowering springs 18x10 Forgestar CF5 all four ZL1 Front conversion Tune |
10-24-2015, 09:09 AM | #2 |
Drives: 2011 Camaro SS/RS Join Date: Feb 2011
i currently have 18x11 rear and 18x8 in the front. 28.8 inches tall so they will not throw a code. i have nitto 555r in the rear and nitto motive 255/45/18 in the front. Car handles well, when i first started i was in your shoes. Yeah it would have been nice to have some front skinnies but i couldnt find a tire for a 18x5 that was within the 28 inches. But i also knew that i couldnt make sharp turns if i had too with skinnies so i went ahead and went with the 18x8 and loved it. I know alot of people go with the 17in setup as well. tires are more available. ill try and post pics if my car with the 18in weld rts wheels on
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
10-24-2015, 02:06 PM | #3 | |
2010 CGM 2SS
10-24-2015, 08:46 PM | #4 |
Drive Fast Take Chances
How's your cornering with the 18's?
2012 45th Ls3 M6:ECS 1500, Custom Cam ,Alky Meth kit, Mcleod Rxt, MGW shifter,Pfadt Tri-y headers Solo Mach X, 20%tint,3.91 gears ,Suspension upgrades, G-force axles.700 RWHP
http://www.slowhawkperformance.com/ |
10-26-2015, 02:30 AM | #5 |
With the 18s you dont have problems with the lca, i know with the 17s you will have to cut into the lower control arm so that it can fit. I know some stores already have it cut already, some people on here have sold some as well. I just put a zip tie on the e-cable and that was about it
10-26-2015, 02:32 AM | #6 |
Corners great, almost like factory to tell you the truth. I live in texas and we have alot of potholes, so sometime you got to make that sharp turn to avoid them, i dont know about making a sharp turn with skinnies in the front or hitting the pothole.
10-28-2015, 12:45 PM | #7 | |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
11-07-2015, 04:43 AM | #8 |
Anyone in here running 17's in the rear just purchased some and want to see what LCA I should run so that it doesn't rub
2010 CGM 2SS
11-07-2015, 03:07 PM | #9 |
Drives: 2009 ZR1 Join Date: May 2010
Unless you modify your stock LCAs, you will need to get one of these:
http://www.bmrsuspension.com/?page=p...d=77&catid=309 |
11-07-2015, 04:30 PM | #10 |
Treasure Coast Camaro 5
Blake-b I thought u only needed the special LCA's if u r lowered to run a 17? U know more than me for sure!
11-07-2015, 04:31 PM | #11 |
Which 1's?
11-07-2015, 04:56 PM | #12 | |
"~ Lowered or stock ride height , replace lower control arem with BMR# TCA28 or TCA29, check clearance on Ebrake cable and swaybar endlinks at ride height" Granted, the OP didn't mention the width of his wheels so I am assuming he went with 10" wide wheels. The 17x9.5 wheels do NOT have the same notation. BUT BMR's description of the TCA028 arms say for use on lowered cars only. So, based on that info, the OP is not lowered, he is limited to the TCA029 adjustable arms which are not quite twice as much. That is one of the reasons I didn't jump on the 17s for sale a couple days ago - I didn't want to buy new LCAs and new tires... I also noted there is a misprint in Weld's guide (arem vs arms) as I copied and pasted from it. Also, some people have said the LCAs only hit from a hard launch and no other time. I've no experience with the 17" welds as I'll get a set of 18s so I don't have to buy new tires. |
11-23-2015, 09:40 PM | #13 | |
11-24-2015, 11:56 AM | #14 |
"Black Ace"
Thanks. Do they stick out much in the rear? Kinda hard to tell from that angle... 'Still wondering what offset to get, since 18x11 isn't in Weld's fitment guide.
