Old 10-24-2015, 11:34 PM   #1
burnningice
burnningice's Avatar
Drives: 2016 SS Mosaic Black
Single vs multi disc clutches
So I'm new with clutches. I may replace my clutch soon and would like some info about the advantages of each type. Most cars have a single disc right? Multi is just performance?
burnningice is offline   Reply With Quote
Old 10-26-2015, 04:16 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Single disk clutches can only handle so much torque before streetability suffers. Under 500 whp single disk is fine. Some guys have successfully run quite a bit more others have smoked them with a stock engine.
Multi-disks increase clutch surface area for handling more power without adversly affecting drivability.
Old 10-26-2015, 07:28 PM   #3
burnningice
I am putting 507 at the wheels. I've not had a problem with my clutch but maybe I should plan on upgrading it. Will I notice a difference in drivability by changing it?
Do I need to get one with a new slave cylinder?
Old 10-27-2015, 12:51 PM   #4
CamaroCracka
Drivability depends on the clutch you buy. You should be able to find one that will hold that power level and be streetable without too much trouble.
Ones that use puck style disks hold more power but have more of an "on/off" feel. There are plenty of full disk clutches that hold 500hp and should feel close to stock.
Old 10-27-2015, 01:44 PM   #5
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Check out Monsters LT1-S. Its a twin disc that drives like stock.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 10-27-2015, 02:20 PM   #6
Justin@CPR
Justin@CPR's Avatar
Drives: 2002 Trans Am
I loved my McLeod twin disc in my 4th gen. Drove like stock!
Justin@CPR is offline   Reply With Quote
Old 10-27-2015, 03:24 PM   #7
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
IMHO new clutch = new slave
Lots of options out there, look for HP/tq ability and a reputable manufacturer.
h018871 is offline   Reply With Quote
Old 10-28-2015, 10:42 AM   #8
CamaroCracka
Whether you replace your slave or not, you should get the billet bearing support from Monster, especially if you intend to slip it while racing.
