Old 10-26-2015, 06:13 AM   #1
TIREKLR
TIREKLR's Avatar
Drives: 2015 zl1
New ZL1 acting strange
Took a ride in the zl1 yesterday and stopped and put gas in it and then drove about 5 miles and shut car off and sat for about 10 min and drove about 5 more miles shut car off and went into the store when I came back out I started the car it said " reduced engine power" "stabilitrac" and it was shaking so hard I thought it was getting ready to throw the s/c off top the engine! So I immediately turned car off waited and restarted to same thing......so I waited 3 or 4 min restarted it ran and sounded great with exception of CEL being on. I drove it straight home and that's were she stayed and I will obviously contact the dealer today ( even though there past practice is very very unimpressive) but I wondered if any of you LS/Camaro veterans can give me a little insight? Thank you very much.
Car is 100% stock 250 miles on it.
TIREKLR is offline   Reply With Quote
Old 10-26-2015, 06:44 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Some new cars have had issues with the ECM and the connections going to it. The CEL light will give the code and it should be easy to resolve. The pins in the ECM connector have also been a problem on some new cars. Other than that, I am sure they will check the main engine harness and associated ground connections.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-26-2015, 08:08 AM   #3
RJ111
RJ111's Avatar
Drives: 2015 ZL1
My car did the same thing. They replaced the ECM, and put a new battery in the car. Its been running fine since.
2013 Camaro ZL1,Victory Red # 441....SOLD
2013 Camaro ZL1, Summit White # 3071...SOLD
2015 Camaro ZL1, Summit White # 1325
Rotofab Cai,PCM cc,Kooks Headers,Cats delete,MF X pipe, ZLWin cam,upper/lower, Lingenfelter hx,715 rwhp,646 rwtq, BMR 1.25 Springs, Varro VD01 Wheels,
RJ111 is offline   Reply With Quote
Old 10-26-2015, 08:36 AM   #4
TIREKLR
TIREKLR's Avatar
Drives: 2015 zl1
This may be off subject but since we are talking about connections I was laying under it spraying the belly off the other day and right inside passenger rear wheel there is exposed connections/wiring is that normal? Looks like it could easily be water damaged and I don't remember my 1le having this.
Old 10-26-2015, 09:19 AM   #5
Stephen12ZL1
Drives: '21 ZLE A10
yes...the connections near the fuel tank and suspension wiring appear to be "unprotected". The magnetic shocks that your 1LE didn't have is the major difference.
Old 10-26-2015, 09:39 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Well this sounds like the key piece of information to me...
The car has only 250 miles in it and your underneath spraying water...
I'm sure you just sprayed some electrical connection and now the car acting all funny.
Mods:
Old 10-26-2015, 11:25 AM   #7
ZL1-V
Drives: 2013 Camaro ZL1
I'm going to say it anyway but that is way too OCD. The only underside of a vehicle I ever cleaned was the Fire Engine on a formal inspection. Now you are second guessing GM engineers and the wiring. If it was damaged by water don't you think they would know since the car has over 5 years, and thousands of owners Good luck with that.
ZL1-V is offline   Reply With Quote
Old 10-26-2015, 11:34 AM   #8
TIREKLR
TIREKLR's Avatar
Drives: 2015 zl1
Haha no that was a few days ago I was underneath washing .....I'm new to FI cars but not cars all together. I did get a good laugh out of that tho. And also yoh are correct I no that they are different animals but though maybe these stood out more because they were unprotected and the bright colors but I honestly did not think of the extra components due to the magnetic ride ( which is soooooo nice) . Thank you all very much though this once again is the reason I like Camaro5 for the knowledge of others that are willing to share! Even if I get harassed now and then haha and I will because I am a very curious person who likes to educate so I ask plenty of questions stupid or not!
Old 10-26-2015, 12:02 PM   #9
TIREKLR
TIREKLR's Avatar
Drives: 2015 zl1
Thanks for your input and yes I'm extremely OCD but if you take the time to read I did not relate the wiring in the rear to my current issuse I ask about it because I noticed it a few days ago and since I was getting feedback from what seemed to be knowledgeable ZL1 owners I ask if they new there purpose. I had drove the car multiple times since "washing" the underside of the car just curious if mine had not be properly wrapped or if all of my fellow owners had this. You are 100% correct in the fact that if those were the issue I doubt they would of made it for this long I just wondered if what I had was normal and Stephen12zl1 being the nice guy he is already cleared that up for me.
Old 10-26-2015, 12:15 PM   #10
mhoskins76
HTWEELZ
mhoskins76's Avatar
Drives: 2013 2SS Hot Wheels Edition
Same thing happened to my brother in-laws car. The replaced the ECM and the battery, been good since. Seems to be that they had some bad ECM's in a batch of them.
2013 2SS Hot Wheels Edition 727 of 1524
w/ Dual Mode Performance Exhaust, Nav, and
Performance Shifter.
DELIVERED APRIL 22nd, 2013 and enjoying every minute since!
Mods:
Cold Air Inductions CAI, CNC Ported Throttle Body, Elite Engineering Oil Catch Can, Smoked Spyder LED Tail Lights, 12" JBL Sub, JBL Amp, Stealth Sub Box, American Racing LT headers and hi-flo cats, Tuned by Davenport, Custom painted interior pieces, Custom painted hood liner and trunk liner, Niche Targa M-130 wheels, LED side markers
mhoskins76 is offline   Reply With Quote
Old 10-26-2015, 12:27 PM   #11
TIREKLR
TIREKLR's Avatar
Drives: 2015 zl1
Hopefully that will fix it. I am supposed to drop it off to them so I will see soon. Thanks for all the help
Old 10-26-2015, 12:42 PM   #12
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
The main power wire at the fuse box had a loose nut. It was creating all kinds of strange issues, service stabilitrack , car shut off after moving about ten feet, the center dic would tell me to roll up and down drivers window. The dealer replaced the fuse box and positive cable. I have had no issues since the fix.
NW Sam is offline   Reply With Quote
Old 10-26-2015, 12:43 PM   #13
ZL1-V
If I came off too strong I apologize, it was my first morning post.
Old 10-26-2015, 01:32 PM   #14
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Was it brand new when you bought it?
jayno20 is offline   Reply With Quote
