Old 10-26-2015, 03:01 PM   #1
Gangsta
Gangsta's Avatar
Drives: 2013 Convertible 2LT/RS
Exclamation Evaporative Emission Problem ?!
Hey there guys, i drive a 2013 convertible 2LT/RS Camaro and lately i got the check engine light on so i checked it using the ELM327 OBD II Scan tool and i got these error codes
P0496:Evaporative emission system high purge flow
P0442:Evaporative emission control system leak detected (small leak)
in the beginning it was only the P0442 but afterwards i got the other one too.
the main problem is when i refill my gas tank the car won't start from the first ignition attempt so how can i solve this ? should i replace the Evap under the hood or the canister near the gas tank under the car ?
i would appreciate some answers specially if u had the same problem
Gangsta is offline   Reply With Quote
Old 10-26-2015, 09:00 PM   #2
TooCool5
TooCool5's Avatar
You have to do a smoke test to determine which sensor.
Do a search on here, most have been the purge valve in the tank.
Old 10-27-2015, 12:54 PM   #3
Gangsta
Gangsta's Avatar
Well, its kinda hard to do that where i live not everyone is a good mechanic you know ..
any other way to find out?
Old 11-23-2016, 12:40 PM   #4
Ppriyam
Drives: 2015 Convertible Camaro 1LT
any updates on this would be much appreciated. I am having the same code.
Ppriyam is offline   Reply With Quote
Old 11-23-2016, 02:02 PM   #5
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
you can get some evap codes from a leaky gas cap. worth checking
maddoggyusa is offline   Reply With Quote
Old 11-23-2016, 02:54 PM   #6
Shifty1
Drives: 2015 Red ZL1
suspect the purge solenoid...
Shifty1 is offline   Reply With Quote
Old 11-24-2016, 07:59 AM   #7
fhrex
Drives: 2011 Camaro 2LT/RS
Purge solenoid is usually fairly cheap and is located under the hood. A fairly easy fix. The evap small leak can be a bit difficult to pin down. Take a look at the o ring around your fuel filler cap. If there is any dirt or debris, clean it and reinstall your cap.
fhrex is offline   Reply With Quote
evap, evaporative, p0442, purge, valve
