Old 10-30-2015, 07:56 AM   #1
fleebag
fleebag's Avatar
Drives: Moneypit
Fuel pump replacement question
I just replaced my fuel pumps and cranked it up, all good. I just remembered I forgot to connect the line at the bottom of the fuel pump bucket. It's the quick connect line that stays in the tank when you remove the pump.
What does this line do? Most important does it have to be hooked up?
Thanks in advance
fleebag is offline   Reply With Quote
Old 10-30-2015, 09:44 AM   #2
avido
Drives: camaro ss\rs
It should be the connection from the other part of the tank.
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 10-30-2015, 11:27 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I believe it allows the bucket's venturi system to pull fuel from another area of the tank during hard cornering, but I could be wrong.
Old 10-30-2015, 11:31 AM   #4
fleebag
fleebag's Avatar
Drives: Moneypit
Thanks
Old 10-31-2015, 09:59 AM   #5
christianchevell
old school chevy rodder
christianchevell's Avatar
wow a new fuel pump/pumps and I work off the stock everything..... you install a zl1 pump for something? planning on cornering a lot?
Old 10-31-2015, 12:40 PM   #6
RankSS
Drives: 2010 Camaro SS
That line draws fuel from the other side of the saddle shaped tank.
You will not be able to use all the fuel in the tank. Best fix it.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
