Old 11-02-2015, 08:46 AM   #1
Reelgrinder
Drives: 2016 SS
3.91 Gears adds to dyno or losses? and boost loss whre to look?
Was wondering does 3.91 gears make your dyno read higher or lower?
Also
I have seem to have lost some HP?
I was making 615 on a mustang dyno last Nov with 10 to 11 psi on the eforce.
I since have done 3.91 gears and the tuner says I'm down to 8 psi IATs read same about 140. out side temp on last years run was 58 deg. Last week it 70 deg.
Belt isn't slipping
Compression is fine
Where could I be loosing 3 psi?
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
Old 11-02-2015, 10:31 AM   #2
cc-rider
Drives: 2010 Camaro SS
It's probably just the atmospheric conditions between the runs accounting for some of the boost. I wouldn't think that boost could change that much...but there was just another post here about a month back where a guy was logging the same amount of boost changes with different ambient temps. The density of the air can change, and temp is a major factor but not the only one.
I wonder if anyone has ever done a study on atmospheric conditions and how that affects boost (keeping everything with the engine/charger fixed variables). Would be really interesting to read and study. I think that all of us that have forced induction have felt the performance of our cars swing from day-to-day.
cc-rider is offline   Reply With Quote
Old 11-02-2015, 10:50 AM   #3
Unreal
Drives: 2006 Z06
Belt wear, air filter, weather, etc. I've seen 3-4psi just cleaning the airfilter.
Gears have no effect on dyno numbers.
Nick
Corvette Z06 -1200ish rwhp
Old 11-02-2015, 11:21 AM   #4
JANNETTYRACING
JANNETTYRACING's Avatar
Also
Belt isn't slipping
Compression is fine
Gears should have no affect on dyno numbers unless your spinning your tires which will affect numbers for sure.
What pulley combo are you running?
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 11-02-2015, 11:57 AM   #5
Reelgrinder
Drives: 2016 SS
Ted.
2.75 and stock cranks..
Unreal..
I have and the tuner has seen belt slippage in the past none is present
can't see how a worn belt would make a difference if nothing is slipping
Borla Headers
Borla Atak
Old 11-02-2015, 11:59 AM   #6
Reelgrinder
Drives: 2016 SS
Boost was 7 or 8 psi in lower rpm then upward rpm it was abt 11.. now down low its 6 or 7 and 8 in upper rpm coming on late.
Borla Headers
Borla Atak
Old 11-02-2015, 12:11 PM   #7
JANNETTYRACING
Belt slip is most likely.
Ted.
Old 11-02-2015, 12:13 PM   #8
AGP Turbo
Drives: All things Turbocharged
Down and up and down?
Maybe your bypass is not holding shut. Something isn't right there.
AGP Turbo is offline   Reply With Quote
Old 11-02-2015, 12:52 PM   #9
cc-rider
Unreal..
Reel-
Are you 100% sure that belt is not slipping? How have you confirmed this?
Not trying to discredit you or call you a liar. But as others have said, it is certainly the most obvious thing. Would suck to go chasing other more complicated things when the most obvious culprit has not be 100% ruled out.
Old 11-02-2015, 01:40 PM   #10
Reelgrinder
Drives: 2016 SS
Pretty sure the curve looked dam smooth.. I had matt Sorian from FSP look at it last year and it did slip with him and you could see it but once I got the upgraded tensioner and green belt Its been ok.. So ya pretty sure.. I saw nothing like before.. but the belt so cheap and my AC belt is pretty crappy down to 3 ribs lol So Ill do them both..
Borla Headers
Borla Atak
Old 11-02-2015, 02:09 PM   #11
Unreal
Drives: 2006 Z06
When a system has a borderline belt system it won't slip at first, but after some mileage it will. Just because it wasn't slipping before doesn't mean it isn't now. With a 2.75 upper if it doesn't have at least an 8 rib I wouldn't expect belts not to slip.
Nick
Old 11-03-2015, 01:31 PM   #12
Reelgrinder
Drives: 2016 SS
I was wrong its a 3" pulley, I haven't put the 2.75 on yet.
Here are the 2 graphs to compare last Nov and 4 days ago.. You would see belt slippage wouldn't' you?
Borla Headers
Borla Atak
Old 11-03-2015, 01:52 PM   #13
Unreal
Drives: 2006 Z06
No you don't see belt slip.
Nick
