Old 11-02-2015, 10:24 PM   #1
Heisenberg
Heisenberg's Avatar
Drives: Camaro 2010
Comp Cams dual springs/retainers/keepers
I am selling these parts. For a LS1-LS3 engine. Brand new in the box/bag.
Please PM best offer.
COMP Cams 26926-16 - Comp Cams Dual Valve Springs
Dual Valve Springs
O.D. Outer Spring: 1.320''
I.D. Inner Spring: .654''
Spring Rate: 505 lbs/in
Seat Load: 129 lbs @ 1.835''
Open Load: 470 lbs @ 1.160''
Coil Bind: 1.100''
Spring Damper: No
16/pkg
COMP Cams 1779-16 - Comp Cams Valve Spring Retainers.
Handle Higher Pressures
4140 Chrome moly
Black Oxide Finish
Superior Strength
Ultimate Stability
Valve Spring Dia. Outside1.29 in.
Manufacturer's Part Number:1779-16
COMP Cams#249-623-16
GM Gen III/LS1/LS2/LS6 Race Valve Locks
Valve Stem: 8mm
16/pkg
Heisenberg is offline   Reply With Quote
comp cams, dual springs, keepers, retainers
