Old 11-07-2015, 12:21 PM   #1
tlwarren08
Drives: Camaro SS
Rattle from underneath w/out a tunnel brace
I have a 2011 SS with Headers, Hi-flow cats, and Borla Atak exhaust. The noise occurs at take off mainly in first, when shifting into 2nd/3rd gear at low RPMs (parking lots/neighbor hood rd). At first I thought it may have been the Brace suggested on other post. I tried using "spacers" still occurred recently took off the brace completely and the sound is still there! Any suggestions? TIA
tlwarren08 is offline   Reply With Quote
Old 11-07-2015, 01:39 PM   #2
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
May be hitting the heat shield, check to see how close your exhaust pipes are from front to back as far as clearance goes. May just need a slight adjustment
JD_Alaska is offline   Reply With Quote
Old 11-07-2015, 02:18 PM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Are the headers touching the steering shaft when you let the clutch out under acceleration ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 11-07-2015, 07:45 PM   #4
CamaroFan22
CamaroFan22's Avatar
Drives: 2SS/RS black with yellow stripes
Something similar and maybe even the same thing happened to me when installed a set of ARH 1-7/8 LTs. Mines a 2011 as well and it made this rattling noise upon takeoff just like you're talking about and it turned out to be this stud that sticks out from the passenger side fender that was hitting one of the header tubes. You might want to take a look. It's easy to see the stud by just looking under the hood. All I did was just saw a bit of it off and that did the trick.
CamaroFan22 is offline   Reply With Quote
Old 11-07-2015, 11:18 PM   #5
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
I had the same thing happen as CamaroFan22 just cut the stud off.
JCunningham is offline   Reply With Quote
Old 11-08-2015, 12:15 AM   #6
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Take it to a muffler shop and have them diagnose it for you. Could be a hanger, defective muffler or cat. At the very least they can weed the exhaust out, but imo its within the exhaust's cat back.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
