Old 11-13-2015, 03:56 PM   #1
Chrisco22
Chrisco22's Avatar
Drives: 2011 Chevy Camaro LS
One Tire mark Burnout?
So not sure this the right spot to post this but had a question. Feel like i always used to lay two tracks.. Why did i only lay one last night (albeit a long, deep track).. auto v6, few power gains, more than capable of decent burnouts but why?
2011 Camaro LS: [Rally Yellow] [22" Status Rims] [BBK Long Tube Headers w/ High Flow Cats] [Trifecta Tune] [K&N CAI] [Blacked out Bow Ties and Tail Lights] [15% Tint] [MAC Mufflers] [Rear Cat Delete] [Vmax Black Ice]
Chrisco22 is offline   Reply With Quote
Old 11-13-2015, 05:18 PM   #2
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Auto V6 doesn't have posi.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 11-13-2015, 06:44 PM   #3
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Yep, Auto no posi.
etmx183 is offline   Reply With Quote
Old 11-13-2015, 07:06 PM   #4
Chrisco22
Chrisco22's Avatar
Then let me ask (not that I'm debating it, actually did some research to confirm that being true), why sometimes do i lay two pretty even tracks.
Old 11-14-2015, 06:59 PM   #5
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
That's weird...are you sure....maybe you did a burnout over the same spot twice. This car does it.....
rontammy0 is offline   Reply With Quote
Old 11-14-2015, 08:07 PM   #6
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
I have an auto V6 and can confirm it's a one wheel wonder- HOWEVER in some instances I've laid two marks down or had it switch the spinning tire from one side to the other depending on conditions. Wherever the path of least resistance, there's where the traction breaks.
I'm looking for a SS rear diff for mine to change ratios and get the posi. I like to draw 11's on pavement and then try convince police it's "art"
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Old 11-14-2015, 08:29 PM   #7
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Yes, the auto V6 is an open diff. Sometimes the one wheel wonder spin comes into play. Only when they are equal power and traction do they both spin equally. It makes for a difficult time for a V6 to get great traction at the track.
Photo is from a few years ago Showing a two wheel burnout.
Video was a couple years ago when at the track, trying to get equal power to both wheels for a good burnout.
Old 11-23-2015, 09:55 AM   #8
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
If the traction is the same on both sides then both tires will spin. The tire with the least traction will spin leaving the other tire stationary if the sides are not even.
Also if your car slides sideways during the burnout them this changes things.
2013 ZL1 #7860 is offline   Reply With Quote
Old 11-23-2015, 11:54 AM   #9
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
I know I have the 3.27 open rear but I don't think I've ever layed down just one stripe. Always two nice ones, maybe because I'm always pointed nice and straight. I'll be buying a rear cradle from an SS regardless though. And I'll definitely be needing it next year!
How well does the stock SS rear do for launching with 500-550whp? When do guys start really needing extra like the Eaton unit etc?
3.6L Twin Turbo V6
Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension
10.75 @ 131mph
JantzenOKC is offline   Reply With Quote
Old 11-23-2015, 01:20 PM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I broke the spider gears in my stock diff 2 months ago, then swapped in the EATON. I'm running high 10's on motor. I had a lot of runs on the stock diff... hundreds.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 11-23-2015, 03:49 PM   #11
JantzenOKC
JantzenOKC's Avatar
I'm sure I'll be fine then. I won't be leaving like you do that's for sure. I'm shooting for 1.70's.
3.6L Twin Turbo V6
10.75 @ 131mph
Old 11-23-2015, 04:51 PM   #12
Skoonie
Drives: 2010 SS M6
My 10 SS has only been leaving one tire mark, the back end is very quick to dance around and I had someone watch to verify both tires are spinning. Only thing I can come up with is one side is spinning much faster than the other and the posi needs work.
Skoonie is offline   Reply With Quote
Old 11-23-2015, 07:07 PM   #13
viper2183
Tampa Bay Camaros
viper2183's Avatar
Drives: 2012 Camaro SS 45th Anniv. Edition
Man I thought that track was gone. I used to run there a few times in the late 70's....
Thanks,
Dan B
viper2183 is offline   Reply With Quote
Old 11-23-2015, 07:35 PM   #14
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
It is more common for a independent rear like the 5th gen to spin both tires over a solid axle car as the driveshaft turns a fixed diff and distributes the power evenly to both shafts.
Solid axle open diffs technically try to lift the passenger tire and push down on the drivers. That's why they pretty much always spin the right rear tire.
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
