Old 11-20-2015, 10:06 PM   #1
Eric1
Drives: '13 2SS 1LE
D1SC Procharger on LSX block
Have a '13 1LE and over the winter will be building a 416 stroker using an LSX block. Just wanted to make sure that the procharger kit I have now will mount up the exact same. Thank you.
Eric1 is offline   Reply With Quote
Old 11-21-2015, 05:52 AM   #2
Trob85
Svt lol
Trob85's Avatar
Drives: 2011 ss inferno orange blown
Should, every mounting point is universal on the Ls engines except that disaster idea of a ls4 (fwd) they put in the Monte Carlo if I remember correctly.
Trob85 is offline   Reply With Quote
Old 11-21-2015, 10:56 AM   #3
hillshooter
Drives: 2015 Camaro SS commemorative
Do a build log. I would be interested to see this. What HP have you hit so far with your setup?
hillshooter is offline   Reply With Quote
Old 11-21-2015, 11:05 AM   #4
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
Upgrade to a F series head unit. That D1 will run out of steam.
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 11-21-2015, 11:26 AM   #5
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
It will mount fine. I wouldn't use a D1 for a 416 though. A F series is more appropriate.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 11-21-2015, 01:47 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I had a D1 on my LSX427. The most i could get out of it was 758whp at 14psi. I had one more pulley to go but didnt bother since twins were in the works. Id go F1C to get the most out of your motor.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
