Old 11-21-2015, 11:05 AM   #1
Cabinetman
Drives: 2015 ZL1
My differential woes
I really want to love my '15 Z, but I'm about fed up with Chevrolet regarding my noisy rear diff.
Within the first week of ownership I noticed some gear whine on coast between 40 and 50mph. I took the car in to the dealer for repair. The service manager heard the whine and agreed to replace the diff. However, the next day I'm told that GM denied my repair and I needed to come get my car.
After the repair denial I contacted one of the GM reps on this board and she set up an appointment with another dealer. I took the car in and went with a ride with the service manager who heard the noise and agreed to fix it. This time GM allowed my rearend to be rebuilt with a new gear set, but would not supply a complete diff. The parts came in this week and the new gears were installed.
The new gears that were installed are more annoying than the gears that came out. I still have some whine on coast, just in a different speed range, and now I have a whine under power between between 62 and 72mph. The service manager agreed the noise is there, but he said they can't do anything until I put 500 miles on the car. He acted like this was a requirement from GM.
It is my understanding that once gears are whining it is not going to go away. I don't understand why I have to drive 500 miles, which may take 2 months, before GM will step up and fix my car. I just want my 5 month old car fixed so I can't stop jacking with this rearend noise and enjoy my Z.
Cabinetman is offline   Reply With Quote
Old 11-21-2015, 12:50 PM   #2
cbarile
Drives: zl1
I think 99% make some whinning. I just had my whole different replaced with a new one and it wines on deceleration between 50-60. The one they replaced whined around same speeds but the clutches were bad. I've had alot of gear changes in ford's and I was told 500 mile breaking and sometimes the wine did get less audible.
cbarile is offline   Reply With Quote
Old 11-21-2015, 01:33 PM   #3
Jeb114
Jeb114's Avatar
Drives: 2021 300
Most rears with a manual shift have a little whine on Decel.
Jeb114 is offline   Reply With Quote
Old 11-21-2015, 01:34 PM   #4
Cabinetman
Drives: 2015 ZL1
I appreciate the input. Most of my gear experience is with Jeeps and if they whined after install they never seemed to get better. Maybe things will improve after some mileage, but I'm not getting my hopes up.
When they replaced the first set of gears there was notation on the paperwork that the tech found excessive metal shavings and uneven wear, so the noise I was hearing didn't appear to be normal. Sadly those gears were quieter than the new set.
Old 11-21-2015, 01:40 PM   #5
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I have had my 15 ZL1 for just over a month and a half now. I just passed the 1500 mile break in finally. My rear diff also had a whine on decel, not that bad though. Its hard to tell how bad it is, cause I have nothing to compare it to. So I changed my diff fluid last week, and the noise is hardly even noticeable now. Changing out the fluid is very easy to do. Mine took like just over three quarts.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 11-21-2015, 04:16 PM   #6
nvydvr
nvydvr's Avatar
Drives: 2015 Red Rock ZL1
What brand fluid did you use? I was considering Amsoil, I have 600 more miles to go on my break-in.
Alex
2015 Red Rock ZL1
Panama City Beach, FL
nvydvr is offline   Reply With Quote
Old 11-21-2015, 04:35 PM   #7
DrkPhx
DrkPhx's Avatar
I would never trust a dealer mechanic to install rear gears. It takes experience, skill and time to get it right. Mine had the gear whine when new, but almost completely disappeared when I changed the fluid. I used the correct GM fluid and added extra limited slip additive to help.
Old 11-21-2015, 04:38 PM   #8
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Yeah, mine is noisy when cruising at slight accel and slight decel when at the 62 to 72 speed range. Mine started by 500 miles and just got worse with time. It really takes away from enjoying the car. I got jacked around by the dealer and gave up on them ever fixing it. Some day I might do something myself or just get a different car.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 11-21-2015, 06:19 PM   #9
Cabinetman
Drives: 2015 ZL1
I agree. This was why I pushed for new complete rear diff, but GM balked. Now things are worse than before and I have to live with it until I can get 500 more miles on the car.
I'm surprised how many Z owners appear to be fine with a little gear whine. I have owned a few other high hp cars including 2 GT-Rs, '11 GT500, 997 C2S, IS-F and an E90 M3 and none of those had gear whine. I know the Z rearend is very strong, but that doesn't mean that gear whine should be a given.
Old 11-21-2015, 07:01 PM   #10
Adam12 ZL1
Adam12 ZL1's Avatar
Drives: 2012 ZL1
I can hear a faint whine also. Doesn't bother me though. My 2000 SS with a Moser 12bolt whined incredibly loud. It held up to years of abuse from 5k launches at the track on a nitrous, so I couldn't complain. On the other boards some people complained about that on the 12 bolts. They went and had them adjusted and then they would break the gears latter. I read that Moser set their backlash a little farther in to help with strength of the gears. I just figured this is why the ZL1 rear had a little whine.
Adam12 ZL1 is offline   Reply With Quote
Old 11-21-2015, 10:11 PM   #11
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
It's not that we are fine with it, it's just that we have given up on GM stepping up on what is a known backlash issue. 2 years ago GM monitored ths site and in a few cases replaced the pig and some of those owners had great success. The chances of finding a mechanic that could or would take the time to set up the backlash at a dealer is nil. Now that the 5th gen run is done I don't think you will see GM as willing to start a mass replacement of these bad pigs.
So Get use to the sound as the pig won't break, but is annoying. I am lucky to had 3500 miles of peace and quiet before mine started, and once it starts it will just get louder as the mesh widens. It is sad my 5 year old f150 just started whining after 56000 miles and my my Z just hit hit 10,000. Maybe we should start a signature page and forward it to Mary's desk...
ZMEnow is offline   Reply With Quote
Old 11-21-2015, 10:43 PM   #12
Cabinetman
Drives: 2015 ZL1
I intend to keep fighting. Ultimately I might throw in the towel and sell the car, but not until I have exhausted every reasonable course of action to get it fixed.
Old 12-06-2015, 10:54 AM   #13
Travis104
Drives: 2014 ZL1
Any updates?
Travis104 is offline   Reply With Quote
Old 12-06-2015, 04:10 PM   #14
Cabinetman
Drives: 2015 ZL1
Originally Posted by Travis104 View Post
Any updates?
Not yet. I contacted the GM rep on this board and just heard back last week. I was asked for some more information, which I provided, and now I'm waiting to hear back. I probably could have gotten the ball rolling faster had I just called, but I like having a paper trail.
I have managed to put about 100 miles on the new gears and the high pitch whine between 62 and 72 has not improved. There is also still some lower speed whine on coast like I had before. The whine on coast is not as bad as before, however I would trade the new high speed whine for my old low speed whine in a second.
