KaBoom1701
Ron Davis or AFCO?
So I'm planning on adding the JRE 125rwhp package in 2016.
I'd figure I'd better beef up the cooling of the ZL1. I'm going to add the D3 reservoir to help add coolant for the S/C. Which one works best....the RD or the AFCO HX? Thx
Mods:
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
Lingenfelter also has a nice HXer with fans and adjustable controller. I run them on both my ZL1's
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
![]() ![]() ![]() Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
I am happy with my Ron Davis heat exchanger and like the price.
![]() Drives: 2014 Camaro ZL1 Join Date: Dec 2014
I have Afco (Black powdercoated) & D3 tank , Both are great & no problems at all .
-Ron davis has no fans like afco -Lingenfelter requires some modifications, Afco is much easier to install .
Lingenfelter 630Hp Package , Afco Heatexchanger , Moroso Catchcan , D3 Tank , Siemens 63Pds/hr Injectors , Custom tune.
#5 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Feel free to give me a call to discuss. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#6 |
Go fast, please.
#7 | |
KaBoom1701
http://www.lingenfelter.com/mm5/merc...E#.VlOMUDZdFuk Any advantages over the RD or AFCO ones?
Mods:
#8 |
CamaroFans.com
I've got a Ron Davis w/ D3 reservoir and it works great. Track tested too
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Ron Davis here.
#10 | |
KaBoom1701
Mods:
#11 |
I got mine from JDP.
#12 | |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
Please feel free to call, email or PM us anytime with questions. Good luck with your build and we look forward to hearing from you soon. Kind regards, Jordan Priestley 888.308.6007 |
#13 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
i have a Ron Davis Rad / HX , got them both from JDP .... both work very well... only small problem i ran into was trying to get the transmission lines hooked up ... because of the over sizing between the two could not connect the factory line to the stock transcooler... just wouldnt bend right. installed a ADM cooler worked fine... just used the plugs that came with the ADM setup to block the inlet/outlet on the radiator.
coolant temps under 180 while cruising around town... probably go out and check some IATs tonight... and i run the lingenfilter/rotofab coolant res ... cant run a D3 with the RD Radiator ... no room. |
#14 | ||
KaBoom1701
Mods:
