11-24-2015, 02:33 PM | #1 |
Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
Ported Throttle Body Data
There are lots of opinions on PBT - whether you get any hp gains or not. Most of them passionate!
However, I've seen conflicting data - does anyone have any dyno data that shows the facts? Or an explanation why some dyno data shows no gain and others may show some gain? Searching for truth!!
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
11-24-2015, 02:51 PM | #2 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
Provided the faster response I received after the swap, was the best performance for dollar upgrade to date, even if the Dyno lied about my gains.
11-24-2015, 03:24 PM | #3 |
Drives: 2014 Ford SVT Raptor SuperCrew Join Date: Jun 2011
A part can perform different on the street versus on the dyno. I do not seek the best dyno numbers. I seek the best real world results.
Phoenix (sold)
2014 Ford SVT Raptor SuperCrew How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
11-24-2015, 03:25 PM | #4 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
This is so simple , get a Bo White ported TB ,or wish you did . Best bang for the buck mod you can do .
OLD GUY FLYING FAST AND LOW
11-24-2015, 06:50 PM | #5 |
Drives: 2011 2SS w/RS PKG Join Date: Sep 2010
I got a VMAXX and better response. No dyno #s as I am all stock.
11-24-2015, 07:31 PM | #6 |
We have seen gains from VMax Ported TBs. I would get this more for the improved throttle response than the HP gains. Very good bang for the buck Modification. We are sold on them but to each his own.
All the best, Jared Royce 888.308.6007 |
11-24-2015, 08:30 PM | #7 |
Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
I agree with JDP. The response is very noticeable. I've never had a problem either.....
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
11-24-2015, 09:37 PM | #8 |
Drives: 2010 Camaro SS Victory Red Join Date: Apr 2015
I am in the market right now to buy one, was looking for real world results then Dyno numbers
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
11-24-2015, 10:49 PM | #9 |
Drives: 2014 Saleen 620 White Label #14-011 Join Date: Dec 2014
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors, ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs, BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned! 573WHP/557WTQ @ 10psi. Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708 |
11-24-2015, 11:25 PM | #10 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Bo White ported TB showed I think a 6hp gain from 4K to redline but seriously you're buying it for the throttle response mostly I'd say. Wish we could do a cable throttle body...
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
11-25-2015, 12:31 AM | #11 |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
When my car was strapped down to the dyno at JRE (with all the mods in my sig) we swapped out my oem unit for a VMAXX one. He tried several pulls on a completely warmed motor and tried several different tweeks to make power and yielded nothing. He looked at me and asked if I wanted to keep it on the car, I told him if it made any definitive power keep it on. As you can see from my sig, I do not have one... I was there for all pulls...
Perhaps this was a bad one? I doubt it, these are CNC milled units so the consistency should be there. There are others out there that modify the blade fixture that might create more volume, or perhaps less disturbed air??? |
11-25-2015, 08:47 AM | #12 |
I have a Bo White PTB stage 2 and do not care what it shows on dyno. I just know the car has better throttle response on the road.
Phoenix (sold)
11-25-2015, 11:34 AM | #13 | |
Drives: 2011 SSm6 Join Date: Oct 2011
11-25-2015, 12:11 PM | #14 |
Bone stock LS3 SS, 2 pulls stock TB then 2 pulls with ported TB.
https://youtu.be/o3bmzY1r3hQ |
