![]() Drives: 2012 camaro ss Join Date: Feb 2015
So I had straighline do some work on ssblackbeauty this week. I decided to go with the brian tooley stage 4 cam with supporting mods and bolt ons. Car had xs 2 in headers the 3 inch all the way out back. Love the manner of this cam and the power wow. I am very impressed.
Before video https://youtu.be/kzzUZuV56uM Cam installed https://youtu.be/anQLBFQuY7E https://youtu.be/nYzl4tUuUqo Here's the chart and numbers. ![]() ![]() All I can say is thank you straightline for the awsome tune and thank you brian tooley racing for one hell of a cam guys.
Stock...for now
Can never go wrong with Brian Tooley
![]() Kayla L. 888.308.6007 |
Thanks man appreciate it.. he said the wcf was high due to it being chilly outside he said it would most likely be around 515hp. I am very impressed with this cam and tune man..just need me some tires for traction and some axles that don't suck haha
Stock...for now
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
Ported heads? If so that be very hard to pick up 30hp due to the wcf
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Congrats. Another one of their customers Ivan S did maybe the same cam and went 122 mph at US41.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
#6 |
![]() Drives: Camaro ZL1 Join Date: Nov 2015
Sounds absolutely nasty! Great power from the BTR cams!
#7 |
old school chevy rodder
would suggest the reading of the print out is limited by the fact it does not show the correction factor applied which is most likely standard not SAE..... And yes the numbers are way different than SAE... As in much higher.....
While its a great cam its not that great as the nightfury and TSP's top cam, the GSX6 etc etc all have more power. It is not always needed though for some engine designs to go with the highest lift or the least LSA just for higher numbers with lesser vacuum and least drivability though versus the wider torque curve and improved driving and easier on the valve train lift etc... I went CamMotion stage three with even lower specs for my 428 as I want wide torque and lessor lift with just .650 springs and good driveability improved some from a tighter LSA, and I added a little to the spec of the cam when grinding. Sensors Silicone Couplers Springs Spring Kits Spring Kit Components Superchargers Supercharger Upgrades Thermostats Throttle Bodies Timing Chains Tools Tuning Software Turbo Accessories Turbos Wiring Valves Payment Options Payment Options Recently Viewed
Naturally Aspirated LS1 & LS2 Stage IV Camshaft Share on facebookShare on emailShare on printShare on twitter Loading zoom ![]() See 1 more picture ![]() RRP: $399.00 Your Price: $389.00 (You save $10.00) SKU: BTR LS1/2 Stg IV Cam Vendor: Brand: Comp Condition: Weight: Rating: ( 1 product review ) Availability: Minimum Purchase: unit(s) Maximum Purchase: unit(s) Current Stock: Out of stock Gift Wrapping: Quantity: Buy in bulk and save Sorry but this item is currently unavailable. Please check back at a later stage. Product Description This camshaft is very aggressive for a daily driver application. Although it's been reported to run at 1200 RPM in 6th gear, very good tuning would be required. With 16 degrees of overlap it has an aggressive idle, and makes great top end power at the sacrifice of some low end torque. The increased exhaust duration will pull very well in the upper RPM's without power falling off like other cams might. Cam specs are 235/242 .621"/.592" 111+3 and comes a 3 bolt timing gear pattern. Lift approaching .650" or more while using stock 15 degree rocker arms with too much open spring pressure can damage valve tips long term. We recommend maximum lift of .630" and maximum open pressure of 400 lbs when using stock rocker arms. I considered this cam and its got good duration....... Glad your built now, I am glad I am again, Remember the cam you got and down the road your going to need to check springs at 25k and most likely change them out if your not really taking it easy on the drivetrain. As its good insurance down the road or they can go south.......
#8 |
OP, Go and enjoy you new found power. As long as you are smiling that is all that matters. Happy Thanksgiving!
#9 |
![]() Drives: 2010 imperial blue LS3 M6 2SSRS Join Date: Aug 2013
Awesome cam! Just installed the Tick Performance Polluter cam in mine about 2 weeks ago! Which is supposedly the same cam. Makes awesome HP and the idle is insane!
#10 |
I do not have ported heads. Couldn't factor $800 for 20 hp idk just couldn't do it since the stock ls3 heads flow pretty damn good. I picked this cam and I am very impressed with it. Not only does it have great performance and a nice torque curve it also sounds so aggressive. I don't care about the night fury or any other cam. I did my research and chose what I wanted for what I am building. I'm not doing a race car I'm building something that sounds mean has gobs of power when I want it and I am still able to strap my kid in the back to go for a cruise to get ice cream. The drivability on the cam is actually great yes it does buck at low rpms easy fix keep it in a lower gear than usual or throw a 3.90 in the ass end to make the lower rpm more usable.
Thanks for the props guys I defiantly didn't expect to make as much power as I did and the idle it's just wow..the camera does not do it justice. Just figured I'd throw all my info up to help fellow enthusiast who are building decide on what they are looking for in a cam. Heres one out of the many to choose from. Yes the polluter and the btr stage 4 cam are the same and Martin at tick and Brian are amazing with these ls motors. I hope they see this post because I am nothing but grateful for their quality parts and straighline with the bad ass street able tune on it.
Stock...for now
#11 |
![]() Drives: 2011 2SS Join Date: Aug 2014
You should post all your build specs, here and on the videos. It might help avoid the same questions over and over....
Which exhaust, are you running cats, mufflers, x pipe, resonators, how much power, which fuel... Blah blah blah What's your favorite color, animal etc hahaha. Which exhaust BTW? It sounds great! |
#12 |
True story I just did it real quick didn't put them on the video.. I am running the xs 2 inch primary to 3 inch exhaust all the way back. They sell a kit with it all together but you have to ask for the 2 inch primary. Not a big brand name but I really like it and not alot of people have it.
Stock...for now
#13 |
![]() Drives: 79 transam with 582cid dart motor Join Date: Jun 2010
Sounds great. I have a similar cam from Brian Tooley.
2010 Camaro (inferno orange, 2SS, RS and such) cat backs, catch can, CAI on the way 79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny |
| Tags |
| brian tooley racing, btr, cam, stage 4, stage iv |
