Old 11-26-2015, 10:50 PM   #1
Reelgrinder
Drives: 2016 SS
built short block for turbo question..
I have a 416 shortblock ready and was going to add a turbo or turbos. Was think of getting a balancer to aide in protecting from vibrations..
Should I get stock size or underdrive?
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
Old 11-27-2015, 06:25 AM   #2
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I have a underdrive on mine.An underdrive won't affect the performance of the turbo's anyways compare to a supercharger setup.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 11-27-2015, 07:56 AM   #3
Unreal
Drives: 2006 Z06
Either way works. Underdrive may have better resale later, and shouldn't hurt anything.
Then again keeping alternator voltage/etc up is nice.
Nick
Corvette Z06 -1200ish rwhp
Old 11-28-2015, 09:35 PM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
This... There is no real benefit to moving to an undersized pulley with a turbo set-up. These cars with all the computers and various signals needed for a start, stay with a standard drive so you don't have to worry about power loss, especially if you are going to be adding additional fuel pump/s, gauges and other power drain devices...
Old 11-29-2015, 02:49 AM   #5
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
I've got a UDP on mine, I installed it when I was full boltons with the intention of going sc. I did have to bump my idol up to keep the volts right.
Now with my current setup it's not even noticeable, with the cam the idol is up anyway and when I want more power I just turn up the boost.
If your trying to get every last bit of power out of a FI engine and your turbos are maxed, then I could see justifying the part. But other than that, I wouldn't waste the money again.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
