Old 11-28-2015, 01:52 PM   #1
Jester06
Drives: 2013 White L99 SS
Glad I got a catch can
So I emptied my catch can after just 3 weeks, here's what I got from it
Current HP/Torque: 413HP/413 Torque
Current mods: Pfadt Tri-y Headers with Hi-Flow Cats, VMAX CNC Ported Throttle body, CAI intake by Cold Air Inductions, Apex Air Scoop/Washer relocation set, RX Catch Can, Stainless Works 3" retro Chambered cat back exhaust, Flex Fuel sensor, 3.91 gear ratio, BMR rear trailing arms, BMR Rear Toe rods
Future Mods: GPI's SS3 VVT cam, 3600 stall triple disc torque converter, Fast LSX 102mm throttle body
Jester06 is offline   Reply With Quote
Old 11-28-2015, 02:20 PM   #2
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I'm still on the fence. On it's face it seems like a good idea. Then I read something about it being a condenser for oil...
Moto-Mojo is offline   Reply With Quote
Old 11-28-2015, 03:47 PM   #3
jc615
jc615's Avatar
Drives: Camaro and Sierra
After having my heads off twice Id say get one. The first time was with no catch can and the results were bad. The second time was with a catch can but it wasn't as good as advertised. It caught some of the excess oil but still a lot of residue leftover. After emptying my current catch can the first time I had more in it than all the times combined of my previous one.
jc615 is offline   Reply With Quote
Old 11-28-2015, 04:03 PM   #4
SteelCamaro
Drives: 2012 2SS LS3
Take shelter, here comes a storm.
SteelCamaro is offline   Reply With Quote
Old 11-28-2015, 04:58 PM   #5
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
Catch cans have been used in diesel engines for, well, forever. As much as I pour out of mine after 5000 miles... There's no way I wouldn't have one.
paul84043 is offline   Reply With Quote
Old 11-28-2015, 04:59 PM   #6
paul84043
paul84043's Avatar
And...... ?
Old 11-28-2015, 05:10 PM   #7
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
Over the course of 6000 miles mine has caught about 1/4th the amount of oil that it's that water bottle....
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 11-28-2015, 05:27 PM   #8
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
What kind did you have and what do you have now?
The Bird is the word!
Old 11-28-2015, 05:34 PM   #9
stock block
Drives: 2015 zl1
I would like to know too , I need to buy one for next summer
when I took the intake manifold off my LQ4 6.0 for my truck build holy crap there was a lot of oil in that manifold, I sold that truck to get the SS
stock block is offline   Reply With Quote
Old 11-28-2015, 05:35 PM   #10
Jester06
If it's anything I have an RX catch can
Old 11-28-2015, 06:04 PM   #11
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
I put a 100% factory stock V8 pushrod engine from 1973 into a car in 1991. The engine had about 200K miles. The engine it replaced was a pushrod V8 made in 1969 and had about 250K miles; the cam was wiped out. The entire car that the 455 was in was 300 bucks, and the upper end work on the 350 was estimated at 600. No contest!
After I put another 85K miles on that '73 engine, I decided to check out the bottom end. The engine ran fine but it was starting to leak oil from the rear main and I had overall low oil pressure so I was wondering about the pickup. Two cracked pistons was what I found. The engine at this time was almost 25 years old and had been in use almost continuously. The engine had also never been opened up before I had it.
A tiny bit of oil mist in the intake charge never bothered that engine; it did not have a short life and the oil mist had nothing to do with the cracked pistons (cracked on the casting lines probably sometime in the 1980s) or the rear main (rope seals get old). It was time for a rebuild and so I rebuilt it.
Catch cans don't hurt. I won't say there's no tech reason behind them. I'm not panicked becasue my LS3 doesn't have one. If I'm "in there" doing something anyway, I'll pick one up and install it.
ChrisBlair is offline   Reply With Quote
Old 11-28-2015, 06:13 PM   #12
stock block
Drives: 2015 zl1
thanks for letting me know
Old 11-28-2015, 07:31 PM   #13
Angrybird 12
I have the Elite Catch can now and had an RX, the Elite catches more oil and is easier to empty.
Just wondering what he had and has now.
Old 11-28-2015, 07:40 PM   #14
Angrybird 12
Well if you think about it engine fuel systems today are a lot different than those made in the 60's and 70's. Those carbureted engines (or for that matter TBI) were flushed with gas and kept cleaner all the way through the intake induction system. With fuel injection we now use much less fuel and its delivered closer to the valves so you get less cleaning from the fuel on the valves and none in the upper parts of the induction system. Anyway on cars with direct injection and no gas to help clean the valves you absolutely need a catch can.
