Old 11-28-2015, 04:51 PM   #1
Reelgrinder
Drives: 2016 SS
Intake manifold for Twin Turbo.
Any gains to be had by buying a MSD Atomic, FAST, or Aluminum Profesional Products intake?
I'm going TT and want to know if it make more power or torque or even throttle response buying an aftermarket one. I like the looks of the atomic the most. I show my car and will miss the way my eforce looked with my show theme.
I have heard the FAST can leak but not sure.
I have to buy a intake so what's another 600.00
2016 SS with Eforce 2300
Borla Headers
Borla Atak
Reelgrinder is offline   Reply With Quote
Old 11-28-2015, 04:57 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Buy a stock LS3 and spend the extra money on something else like towards a meth kit, suspension items, tires, gas. The stock LS3 intake is pretty hard to beat unless you are doing a max effort build.
Numerous people have made over 1kwhp with the stock intake and throttle body.
Old 11-28-2015, 05:16 PM   #3
stock block
Drives: 2015 zl1
I'm no expert but the videos of the fast being taken apart to show the portable intake runners makes the manifold look weak and thin , id go with the aluminum for the extra thickness not flow
stock block is offline   Reply With Quote
Old 11-28-2015, 05:33 PM   #4
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
My buddy made 886rwhp with twin turbos with the stock intake manifold. The stock flows perfectly well.
Save the money for something else.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 11-28-2015, 05:34 PM   #5
pincushin3819
pincushin3819's Avatar
Drives: 11 AGP TT SS, 14 ECS C7
Like blake b said stock tb, manifold & heads are good for well over 1000 rwhp. Atomic looks cool for shows but I don't know about it psi rating if it's anything like the fast I would use it if it was for free. Custom aluminums are pretty expensive unless your trying to integrate a custom meth/nitrous system I wouldn't bother. There are couple hi raise options also if you want to go that route.
pincushin3819 is offline   Reply With Quote
Old 11-28-2015, 05:37 PM   #6
pincushin3819
P.S. I'm at 1053rwhp or so with a stock tb, intake manifold & heads.
Old 11-28-2015, 05:47 PM   #7
pincushin3819
That's a bad a$$ picture!
Old 11-28-2015, 05:51 PM   #8
Reelgrinder
Drives: 2016 SS
Ok sounds good.
Borla Headers
Borla Atak
Old 11-28-2015, 05:56 PM   #9
blake-b
blake-b's Avatar
Drives: 2009 ZR1
If you decide you need a Holley Hi Ram or mid rise (I wouldn't consider it as it hasn't shown any gains in the posts I've seen), you will have to cut your cowl and lose your passenger wiper. With the hi ram, you'll need a cowl hood because it won't clear the stock hood.
However, my advice is still stock LS3. Have it hydrodipped in a pattern pleasing to you if you want it to stick out a little (eye candy).
Old 11-28-2015, 06:08 PM   #10
Unreal
Drives: 2006 Z06
Stock intake has made over 1500rwhp.
Put the money into suspension/tires/drivetrain. Intake manifold is a complete waste of money at anything <1400rwhp.
Nick
Corvette Z06 -1200ish rwhp
Old 11-28-2015, 10:04 PM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
My untouched factory intake manifold and throttle body was on the car for 1700 ish RWHP with spray, 1330 with boost only.
We only moved to a sheet metal intake when we started aiming for 2000 + RWHP on boost only. We no longer have nitrous on the car...
Old 11-28-2015, 10:30 PM   #12
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
I would agree to this," Have it hydrodipped in a pattern pleasing to you if you want it to stick out a little (eye candy)". look at Blake's profile he has a picture of one hydrodipped and looks good
Moreair1 is offline   Reply With Quote
Old 11-29-2015, 12:51 AM   #13
BadAquaBluSS
H-Town Camaro Club
BadAquaBluSS's Avatar
Drives: 2010 ABM 1SS/RS, Red 85 Z28
been awhile since I've been on here, looks like that car has turned into a real beast nice job man 2000 hp wow!!!
AGP Twin Turbo, RPS Triple Carbon Clutch, ZL1 Diff with 3.73 gears and Kooks 3" Stainless Steel Exhaust with X Crossover, Kooks Stainless Steel Mufflers, Go Fast Bits EBC, AEM Methanol injection and AEM gauges UEGO and Fuel pressure, Livernois's dual fuel pump, KB Boost a Pump, AUS 1000cc injectors, Full BMR suspension with Koni shocks, JDP Color Changing Halos, Color Changing Scanner Light Bar and Rockford Fosgate T Series Amp's Kicker L7 Sub's.
Build Thread:
http://www.camaro5.com/forums/showthread.php?t=400372
BadAquaBluSS is offline   Reply With Quote
Old 11-30-2015, 05:07 PM   #14
stevieturbo
Drives: it changes
Whilst there is no doubt OEM works superbly, it does seem some of the aftermarket intakes do still help things, perhaps more so if using higher rpm's
If staying below 6-6500rpm, OEM just works. If wanting a little help at the top end, the likes of the Atomic could be worth it for you, especially as it sounds like you have no intake to start with anyway.
stevieturbo is offline   Reply With Quote
