Old 11-30-2015, 12:17 PM   #1
gbu27
Drives: 2013 ZL1
ZL1 question:using PTM at the track
I have been going to a track that's 3 miles from my house, a little 1/8th mile that doesn't even have time working or slips. That makes it a bit hard to see how I'm doing. My question of the PTM is, is it worth using or should I go full traction control off? I put it in PTM5 but half the time at least it seems the PTM makes the car fall on its face off the line. It will spin a bit, kill power then let it come back. This is with drag radials.
gbu27 is offline   Reply With Quote
Old 11-30-2015, 04:35 PM   #2
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Always run at the strip with everything off.
mrvenicess is offline   Reply With Quote
Old 11-30-2015, 08:12 PM   #3
gbu27
Drives: 2013 ZL1
Yea that is what I will try next time I go. I just thought it was suppose to help at the strip as well. The no lift shift should still function with all nannies off correct? I'm sure I read no lift shift is always available.
Old 12-01-2015, 08:04 AM   #4
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
That is correct
2013 A6 ZL1
Redlineviper is offline   Reply With Quote
Old 12-01-2015, 04:16 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Run with all nannies off, unless you are spinning a ton and have trouble controlling it with your foot.
With drag radials, I would venture to say that you should be able to launch better/cut a better 60' with no nannies.
Ideally, you would be a track with timers and be able to compare nannies vs no nannies
Old 12-01-2015, 06:43 PM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I never had any luck with PTM 5...turn off everything via a 7 sec push of the traction control button
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-01-2015, 08:57 PM   #7
gbu27
Drives: 2013 ZL1
Since the track doesn't have times, I may eventually have a vbox or whatever it is called so I can see some times.
Old 12-02-2015, 05:51 AM   #8
big dave
Drives: 2017 ZL1
On street tires I always run in PTM5. I never had any problems with it and on street tires it allowed me to pull mid 1.6 60' times stock. Now that I have drag radials, I turn everything off.
Now because you have a manual, maybe it is a bit different. I assume that because you're nose diving after spinning, the computer is trying to not let things get out of hand. If you turn everything off, you're going to have to try to control wheel spin yourself. Good luck.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 12-02-2015, 06:20 AM   #9
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Where in NC are you and what track is this?
BFASTNOTLAST is offline   Reply With Quote
Old 12-02-2015, 10:43 AM   #10
gbu27
Drives: 2013 ZL1
It's the nahunta drag strip in Goldsboro area
Old 12-02-2015, 10:45 AM   #11
gbu27
Drives: 2013 ZL1
I don't think I'll have any issues controlling it with everything off. I've had another car that was quick with no traction control on it period
