![]() Drives: 2012 Camaro 1LT M6 Join Date: Apr 2012
2012 LFX Clutch won't release
Hi guys, I have a 2012 V6 with 30k miles and recently when I pulled into my house the clutch would not release. It seems to be stuck all the way down with about a few inches of play. Now I can not get the car into any gear due to the clutch won't go down far enough.
Is there anything I can do/check/fix myself before taking it into the shop? It's not drivable now so I will have to have to towed and of course it couldn't happen at a worse time with my money situation, any advice or help would be greatly appreciated. Thanks... |
![]() Drives: 2012 2LT Join Date: Aug 2013
Check your slave cylinder for leak, may be the seal is broken. I hope the clutch is still good. 30k is too soon for clutch replacement.
Jack |
Jack |
![]() Drives: 2015 1ls Join Date: Nov 2015
hope everything got worked out
Thanks for the suggestion! I'll have to google /you tube how to do this. I'm not very mechanically inclined so hopefully I'll find something
I would agree too that at 30k miles the clutch going out shouldn't be (hopefully) the issue. |
| Tags |
| clutch, clutch problems |
