PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Deck lid release wiring diagram?
Can anyone share the deck lid release wiring diagram for the 5th gen? Mine's a 2012 if it matters. The relay under the dash clicks from the button and remote, the lights flash but lid won't pop. Pretty sure it's the latch but would like to verify before spending $80-90. I have 12 v on one pin of the latch until the relay clicks and it drops to zero for the time the relay cycles. Seems backwards but who knows. I searched to no avail. Thanks in advance.
PHAT B33
Anyone?
PHAT B33
Update: Found an ancient thread from 2009 that said to push down on the lid and it worked. After some adjustments to the lid and lube to the latch it's working fine now.
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
Seen your 1st post a few days ago and I couldn't find any info. I use this lube on a lot of things, hinges, latches etc. It's safe to use on plastic. Part# 121346241. Glad you got it working.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
PHAT B33
I ended up using silicone based Superlube gel, never had any issues with it. Thanks.
#6 |
PHAT B33
Update: Intermittent no trunk open returned. Checked relay coil and contacts in dash fuse panel and it was fine. Found intermittent contact on 10A fuse, fuse tested good and with a different load but not in the trunk popper spot. Replaced fuse with a new one and it's ok now.
