12-09-2015, 08:21 PM | #1 |
Drives: 2018 2LT/RS Conv Join Date: Jun 2013
Tires slowly lose air
2013 RS with the 8" front wheels and 9" rear. Since I first got the car it did lose a little air over time. I has Perelli tires. Last April, when I exchanged the wheels with LA Tire and Wheels for chromed factory wheels. Since then the slow air leak has increased. I can set the TP to 35 psi and around two weeks later, whether or not it has been driven or just sitting, it will be down to 32 or 33. This has happened during warm weather or cool, so temperature is not a factor. It happens with all four wheels, so it doesn't seem like it would be from a blemish on the rim or a bad seal on the valve stem. I have a minivan with Continental tires and an F150 with Michelins and never have had a similar problem. The only thing I can think of is that it is a characteristic of the Perelli tires. Any other ideas? Has anybody else had a similar problem? The car now has 16K miles on it. I am not real happy with the Perelli tires, but don't want to replace them with only that low mileage, but am really impressed with the Continental tires on my van. Thanks for any input.
12-09-2015, 08:25 PM | #2 |
Drives: Camaro SS 2SS Convertible Join Date: Mar 2015
I have P Zeros and have never put any air in them (let me take that back , I put some extra air in for winter storage
12-09-2015, 08:33 PM | #3 | |
Drives: 2016 2lt RS Join Date: Oct 2015
12-09-2015, 11:07 PM | #4 |
My 2ss does the same thing but it all depends on how hard u drive and air temperature out side plays a huge roll
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
12-09-2015, 11:20 PM | #5 |
Drives: 2014 1LT w/RS Summit White Join Date: Aug 2015
Putting air in them while they are cold?
12-10-2015, 12:01 AM | #6 |
12-10-2015, 03:31 AM | #7 |
My 14,RS does the same thing. I have 2 sets of wheels and tires and I lose pressure in all of them. Drives me crazy.
12-10-2015, 04:46 AM | #8 |
Drives: 2013 ZL1 Hennessey 800 hp upgrade 7 Join Date: Nov 2014
Any of you filling your tires with nitrogen??
Sent from my iPad using Tapatalk
2013 ZL1 vert
HPE 800 hp upgrade 750 rwhp 751 rwtq Newbury, Ma |
12-10-2015, 04:48 AM | #9 |
Have never had any issues with my P Zeros. As expected, when the weather turns cold I have to add a few pounds. When it warms up I have to let a few out. No problem.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
12-10-2015, 05:31 AM | #10 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
My G2's have a range of 28 (cold mornings or after sitting extended periods) and 37 driven in blazing summer. I always use the factory recommend psi of 32 square. My right front usually loses a pound or two vs the others.
12-10-2015, 06:36 AM | #11 |
Drives: 2012 1LT Drop Top Join Date: Oct 2013
A few pounds either way is normal. I see it fluctuate all the time depending on the temperature. Just fill a pound or two over recommended so it doesn't drop low.
12-10-2015, 07:47 AM | #12 |
Drives: 2014 Summit White 2SS/RS M6 Join Date: Aug 2012
same problem here, 2 front are ok , driver back looses a lot of air (fill with 37, 2 weeks later it might be at 34) back passenger not as bad as driver back tier. i took it to the dealer ,but they couldn't find anything wrong with it. i even tighten the stem valve thing on all 4 and still losing air. it's been happening since day 1 (about a year)
12-10-2015, 07:55 AM | #13 |
The low profile tires have less air in them so any variation in pressure is going be much more noticeable that in a larger tire.
Mine do the same thing. My G2's will vary as much as 4 to 5 psi from cold to warm. It's normal. |
12-10-2015, 08:02 AM | #14 |
my 2013 never did this and i had the low profile tires
