Old 12-13-2015, 06:37 AM   #1
Camarosrock
Drives: None anymore, sadly
Is there a difference between SS and Z/28 diffs? Can you buy and fit a Z/28 diff?
Hi everyone! I was wondering if there is a difference between the Z/28 diff, and that of a normal SS. I seem to recall reading somewhere here that the two diffs were indeed different. I know the Z/28 has a helical system - does the normal SS have a clutch type diff?
I also recall reading that the Z/28 diff is a restricted part, ie you can only buy it if you actually own a genuine Z/28. Is that correct / still the case?
Thanks in advance for any help!
Camarosrock is offline   Reply With Quote
Old 12-13-2015, 06:10 PM   #2
Synner
Drives: cars
Z/28=Helical, 3.91, diff cooler
vs
SS=clutch, 3.45 or 3.23, no cooler
vs
1LE=clutch, 3.91, no cooler
People have been getting the Z/28 parts, you just may have to do some calling around.
Old 12-15-2015, 02:11 PM   #3
Camarosrock
Thanks for the infos!
Old 12-18-2015, 03:33 AM   #4
Camarosrock
btw, would the Z/28 diff fit in a normal SS without any modifications? Is it a straight swap, would it mate to the halfshafts, or do you have to do some other modifications? I heard for example that the ZL1 diff requires modifications for the exhaust manifold due to clearance.
Old 12-18-2015, 08:25 PM   #5
ggionyae
Drives: camaro
that right,you just may have to do some calling around.thanks
ggionyae is offline   Reply With Quote
Old 12-18-2015, 08:36 PM   #6
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Yes, it's a straight swap, except you would need to get the plumbing for the diff cooler (if that matters to you). I looked at this option, and decided it was more cost effective to install a TrueTrac in my 1LE differential.
AG1LE is offline   Reply With Quote
