Old 09-19-2009, 11:39 AM   #1
RickyTheStorm
Drives: '10 Camaro 2SS,04 Colorado,06 ZX6R
Question ARH only to the cats?
Is there a way to get the ARH system but only to the cats - not include the piping and x-pipe to the axle? I have someone ready to do a custom exhaust but I want to get the long tube headers on first but don't need the stuff after the cats.
Thanks!
Vararam CAI, ARH Headers, Flowmaster Exhaust, Nitto NT555Rs, Custom CAM and Tune - 11.981 @ 116.27
IOM - 2SS/RS - Auto - IAP - Sunroof - Ordered 10/13 (#7 at dealer)
3000(accepted to production ): 4/19/09
3300 (scheduled for prod ): 5/11/09
3400 (broadcast ): 5/16/09
3800 (produced ): 5/22/09
4150 (invoiced ): 6/01/09
4200 (shipped ): 6/01/09
5000 (at dealer ): 6/12/09
6000 (delivery to me ): 6/12/09
RickyTheStorm is offline   Reply With Quote
Old 09-19-2009, 12:49 PM   #2
RickyTheStorm
Okay, contacted them direct - they do have a system - next question
Do I HAVE to get a tune with long tube headers?
Old 09-19-2009, 12:49 PM   #3
TeddyP25
TeddyP25's Avatar
Drives: 2SS
YES
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 09-19-2009, 12:51 PM   #4
Melson
Melson's Avatar
Drives: Wild Cherry
It would be best.............
2010 RJT 2SS/RS L99 CAMARO
ARH 1 7/8" LT HEADERS W/ HF CATS
MAGNAFLOW 3" COMP EXHAUST
ADM PERFORMANCE CAI
ADM PERFORMANCE CUSTOM TUNE
ADM PERFORMANCE PORTED THROTTLE BODY
ADM PERFORMANCE TRANS COOLER
3.45 GEARS
BMR TRAILING ARMS
Melson is offline   Reply With Quote
Old 09-19-2009, 12:54 PM   #5
H3LLJumper
H3LLJumper's Avatar
Drives: 2010 Camaro 2SS VIN#11184
Yes.
Lingenfelter 550 HP TVS2300 Supercharger Package, Hennessey CAI, Pedders Extreme XA Drag Package and Sway Bars (waiting to take delivery) Painted gills, stripe, and bow ties, tinted windows to 30%, smoked lights, Orange headlight/fog light halos, NOWEEDS, and GMPP Exhaust
H3LLJumper is offline   Reply With Quote
Old 09-19-2009, 01:28 PM   #6
iwanttogofastNY
iwanttogofastNY's Avatar
Drives: 2010 Camaro 2SS/RS ABM
http://www.camaro5.com/forums/showthread.php?t=41583
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes).
Coming Soon: 4:10 Gears?
iwanttogofastNY is offline   Reply With Quote
Old 09-19-2009, 01:36 PM   #7
john98ssfbody
Drives: 2002 White SS Camaro
If you install the complete system with all the o2 sensors in place, you should be OK. The system shouldn't set any DTCs at all. While a tune will optimize the headers it really isn't necessary.
john98ssfbody is offline   Reply With Quote
Old 09-19-2009, 01:42 PM   #8
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
If you want to make the most out of the system you'll want to get a tune. I would suggest going with the ARH Cat-Back header system which is the one you're talking about and then using Magnaflow part # 16483. It's a 3" Cat-Back with a Tru-X Pipe, Mufflers and tips. If you have any questions please feel free to call or email us anytime!
Kind regards,
JP
JDP Motorsports is offline   Reply With Quote
Old 09-19-2009, 04:02 PM   #9
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
WRONG long tubes will throw codes regardless. I have their full system and the o2 sensors are installed and it was fine for 3 or 4 days then check engine like came on. Longtubes will require a tune to remove codes to pass inspection. And as others have mentioned a tune will also maximize their power and efficiency.
jpsuperman81 is offline   Reply With Quote
Old 09-19-2009, 05:54 PM   #10
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the small bullet cats that come with all the long tube set-ups just are not as efficient as the stock 4 cat system and will eventually set a code, also since you move the front o2 sensors farther down in the long tube collector, most people will get a code for insuficient switching bank 1 and 2,, just the way it is,, not just a problem with camaro's , i have also installed several sets of long tube headers on c6 vettes and they have the same issues
nothing a tune cant fix!
Old 09-19-2009, 09:38 PM   #11
ADM PERFORMANCE
Drives: Anything I want
Kind regards,
JP
This is the best way in my opinion to buy it..2 of my customers here have this setup and both love it.My 427 will soon have it this way as well....Really sounds good.
Andy
www.admperformance.com
ADM PERFORMANCE is offline   Reply With Quote
Magnaflow Exhaust 2010 Camaro JDP Motorsports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 95 05-24-2010 01:17 AM
ZZ-Motorsports: ARH Systems on order at the best prices ZZcamaro V8 Bolt-Ons & Tunes 61 10-01-2009 04:38 PM
3" Magnaflow Installed with ARH Headers - BEST SOUND EVER! ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 42 09-10-2009 12:45 PM
Request: L99 w/ ARH LT Headers w/ high flow cats and SLP LM (1 or 2) Exhaust StlRomAniaN 5th Gen Camaro SS LS LT General Discussions 2 08-28-2009 10:08 AM
Ohhhhh C-A-T-S Cats Cats Cats!!!!! acscamarochick06 Off-topic Discussions 1 01-14-2008 03:57 PM
