Old 12-14-2015, 04:20 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Lsa blower question
If I'm at 10 psi running a 2.5 upper pulley. How much boost might I see with a 10% overdrive crank pulley?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 12-14-2015, 06:17 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
What's the diameter of a 10% lower? Use that to calculate the rpms and see if it's worth it
ttshovel is offline   Reply With Quote
Old 12-14-2015, 06:28 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Sending PM
Old 12-14-2015, 11:26 PM   #4
smokum
smokum's Avatar
Drives: 2010 2ssrs
Here is a helpful chart.
http://weaponxmotorsports.myshopify....ng-mods-needed
smokum is offline   Reply With Quote
Old 12-15-2015, 04:01 AM   #5
2010_camaro
Well my car has the stock ss crank pulley. Idk what the measurements are.
Old 12-15-2015, 05:06 AM   #6
ttshovel
ttshovel's Avatar
I believe it's a 7.8 lower on the ss
Old 12-15-2015, 05:27 PM   #7
JDP Sales
JDP Sales's Avatar
+2 lbs. I'm working on the most cost effective 8 Rib setup for you. I'll reach out with that info shortly.
All the best,
Jared Royce
888.308.6007
Old 12-15-2015, 06:24 PM   #8
hammdo
'It's an experiment'
hammdo's Avatar
Curious -- 2010_Camaro, are you looking to use an LSA drive assembly on your conversion? I can see an overdrive pulley available for that.
I'm wondering if there has been a 10% overdrive pulley for the LS3/L99 -- have not seen those if there is one...
-Don
747 RWHP 794 RWTQ
Old 12-18-2015, 09:22 PM   #9
2010_camaro
All the best,
Jared Royce
888.308.6007
I'll be waiting
Old 12-18-2015, 09:29 PM   #10
2010_camaro
-Don
I found a 8rib conversion with 10% overdrive but it's $1100
Old 12-18-2015, 10:38 PM   #11
hammdo
hammdo's Avatar
Really? JDP doing that? With the power you're seeking, is that worth the upgrade?
Thanks!
-Don
747 RWHP 794 RWTQ
Old 12-19-2015, 09:17 PM   #12
2010_camaro
I already have belt slip with my current set up. Dropping anotger pulley size on the supercharger and going bigger on the bottom will require a 8rib belt minimum.
Old 12-24-2015, 04:31 PM   #13
2010_camaro
All the best,
Jared Royce
888.308.6007
Anything?
Old 12-24-2015, 09:20 PM   #14
hammdo
hammdo's Avatar
So, you're going 2.38 -- 8 Rib -- makes sense in that case. I thought ADM was also working on an 8 Rib too...
That is going to be a 'hot rod'!
-Don
747 RWHP 794 RWTQ
