Old 12-15-2015, 04:59 PM   #1
dgritti
dgritti's Avatar
Drives: 2013 v6 2 LT
NEW CHEVY 350 BUILD
Hey guys so i have a buddy of mine and he had a old 81 k10 chevy and had a 350 motor in it. He has recently yanked it out striped it down to just the block and sent it in to get machined and boared 20 over.
Well i was helping him move and didnt know he just had it laying around. so he wants to sell me it for 500 bucks for the block and all the parts.
Its got a new machined crank and fresh block but things like pisons and heads are old.
I think i might pick it up and start building it from the ground up. The big question is what do i build it up to. Turbo build? Supercharged build? Nos build??
thinking about making it powerful. more so leaning towards a turbo build and put some fatty turbos on it just build it up to be a fun engine.
Then once i get the drive train in order with tranny and motor all that jazz gotta find a old school car to put it in
so torn between c10s, camaros, chevelle, cudas (if i can find one), or monte carlo, GNX,
will keep updated on the build process just thought id post something and see what eveyone thinks
enjoy.
dgritti is offline   Reply With Quote
Old 12-15-2015, 09:11 PM   #2
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
If you buy that block the very first thing you should do is to make sure that it was properly crosshatched so the cylinder walls will retain oil and provide adequate lubrication for the rings. The OEMs and ring manufacturers have developed very specific surface finish and bore geometry specifications for their engines and rings. Also consider what type of rings you are going to use Cast vs. molly rings. Just be sure that the bore finish matches the ring either way you go.
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
Old 12-15-2015, 09:46 PM   #3
dgritti
dgritti's Avatar
Yeah i have all the specs from the machine shop so i know which route to go there and get that covered with. Id say in a couple weeks or a month ill have started purchasing some of the parts for this thing
build, camaro, chevelle, chevy, engine
