Old 12-15-2015, 09:51 PM   #1
songsj
Drives: 2015 2SS/RS Summit White
Paintless dent removal
Has anyone used paintless dent removal on their hood with the decal/stripes. I have a car with one dent about the size of a quarter that is on the hood decal?
songsj is offline   Reply With Quote
Old 12-15-2015, 10:09 PM   #2
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Doubt the adhesive is strong enough to suck it back up without the vinyl lifting/getting warped. You may have better luck trying to push it up from the underside with some heat, if you can even get to it
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 12-15-2015, 10:18 PM   #3
songsj
I was wondering if a professional PDR shop could do it?
Old 12-15-2015, 10:23 PM   #4
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Pdr is done from the underside. I don't see how the vinyl will hurt the repair.
rontammy0 is offline   Reply With Quote
Old 12-15-2015, 11:37 PM   #5
songsj
I was wondering more if the repair would hurt or crack the vinyl?
Old 12-16-2015, 12:00 AM   #6
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
If this is the case, the vinyl will be fine
Old 12-16-2015, 03:25 AM   #7
rontammy0
There may be the odd time they work from the top.....but with dents being considered a negative deform in the quality dept They are worked up that way they can control the amount of lift as they go. That's just from what I've seen. Maybe some guys that do it can chime in.
Old 12-16-2015, 08:54 AM   #8
rontammy0
The vinyl will be fine
Old 12-16-2015, 01:28 PM   #9
Sickness91Z28
Reaper Crew
Sickness91Z28's Avatar
Drives: Blown 2010 Camaro SS
The problem with vinyl decals is that they do not cast a reflection very well. PDR is done off of pure reflection and shading....so you can see the depth and the area of the damage area.
I have fixed a few with vinyl decals and I've had to place a piece of gloss tape over the area. That way, the entire distorted area can be seen. If you see a dent the size of a quarter on vinyl....it's probably more like the size of half dollar...just because you cant see the entire distorted area because of the reflection.
2010 Camaro SS
SLP TVS2300 Blower, Blower Cam, Lingenfelter Heads, Meth Injected, 5lbs of Boost@700 BHP
Pedders XA Coilovers
Sickness91Z28 is offline   Reply With Quote
Old 12-16-2015, 05:05 PM   #10
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
If I wanted cooking advice I would never ask for it at McDonalds.
Pick up the phone, call a PDR shop and ask them.
No dog in this fight anymore.
5th Gen owner 2009-2016.
two_wheel_mayhem is offline   Reply With Quote
Old 12-16-2015, 05:24 PM   #11
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
And I always believed the hood was aluminum and they can't pdr aluminum....
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 12-16-2015, 05:40 PM   #12
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
any PDR (an all other businesses for that matter) are going to say "sure, we can do it. Bring it in!" and once youre in, they got you hooked. I am pretty sure the OP is asking if anyone has had experiences with any PDR's and how well they performed. hes only obtaining info, like all of us on our previous posts.
kmarshall2121 is offline   Reply With Quote
Old 12-16-2015, 06:42 PM   #13
rontammy0
Sure it's a lot of reflection but also the ability to see the deform without relying on paint reflection. I think the vinyl would give off enough shine to see the highs and lows. But your right the deform is likely larger then the op thinks. This may help him a bit because it might not be such a sharp deform.
Old 12-16-2015, 07:01 PM   #14
Sickness91Z28
Reaper Crew
Really not trying to be a jerk but I've specialized in PDR for 9 years and I know exactly how it is working with metal. And yes, it has 100% to do with a panels reflection to do a repair, that's why we use a light and/or reflector boards to do the repairs.
As for aluminum panels, (Camaro hoods along with mustangs and challengers are aluminum) yes they are fixable, just depends where and how big the dent is.
2010 Camaro SS
