Old 12-17-2015, 12:55 PM   #1
Mustang Sally
Drives: N/A 2014 2ss/Rs Silver Ice Metallic
Nitrous without tune
Hey was up guys just outof curiositie can you run a 50-100 shot without a nitrous tune?? Safely ?
Mustang Sally is offline   Reply With Quote
Old 12-17-2015, 01:30 PM   #2
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
only if that shot also shoots extra fuel.
in a sense, that would be tuning the system, but you might get away with not touching the factory ECU (in a hypothetical mental masturbation kind of way).
You wouldn't be able to adjust spark either.
I wouldn't do it.
FunkedOut is offline   Reply With Quote
Old 12-17-2015, 01:36 PM   #3
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
I'd be worried about the timing- but then again if you tune for nitrous and don't use nitrous all that often... seems the timing would be way off and hurt performance when not spraying.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Old 12-17-2015, 02:06 PM   #4
Mustang Sally
I wouldn't do it.
Topic came up last night at the street race and it didn't sound safe at all ������
Old 12-17-2015, 02:24 PM   #5
flyer08
Drives: 2010 2SS/RS
Why you have controllers.
flyer08 is offline   Reply With Quote
Old 12-17-2015, 02:56 PM   #6
Aikidoshadow
Rabbit of Caerbannog
Aikidoshadow's Avatar
Drives: 2010 2SS/RS LS3
Ability yes, depending on gas quality the timing doesn't need to be brought down with a small shot wet kit.
Safety, well if you were worried about safety then you would tune for it wouldn't you?
Anytime you add a large power adder to provide durability you re-calibrate the PCM.
Aikidoshadow is offline   Reply With Quote
Old 12-17-2015, 07:08 PM   #7
VTSummit
Right- but the OP was inquiring about tuning for it or not, no mention of controllers. I'd be curious what controllers people have had good luck with. I've been using nitrous for years, but mostly multi-stage with old school controllers on Mallory ignitions.
Nitrous systems these days seem overpriced compared to what they used to be. Just a simple bottle/jet dry shot kit is pretty expensive considering there's not much to it.
Old 12-17-2015, 07:18 PM   #8
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
LNC-2000 to pull timing and a WOT/Window switch and you'll be good with a 50 no doubt. A 100 would most likely be ok but there is a small amount of risk involved at that point.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 12-17-2015, 07:36 PM   #9
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Use a wet system with an LNC 2000 to pull timing, a window switch with tps and non projected plugs. Keep the factory tune.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 12-20-2015, 10:25 PM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
this
I would run only a 50 shot with higher octane if you dont wanna retard timing, which is the 'only tuning' you do to your pcm for nitrous. Of course there is all the A/F ratio tuning you have to do with jets but with recommended jets you are usually alright with a 50 shot, even to 150 np. Just be sure to always have fuel.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
nitrous, no tune
