Old 09-19-2009, 08:40 PM   #1
bluch
OH CANADA!
bluch's Avatar
Drives: 2011 RAM 1500 LARAMIE
Oil Pressure?
hey guys. i have a car question for you.
I got my car back from an oil change today. They put 6 liters of synthetic oil in. I notice that when I accelerate from idle that my oil pressure gauge jumps almost to 500 kpa (the highest reading on the gauge). Once I start going a constant speed (like 40 km/h - 80 km/h) it goes back down to around 250 kpa (the middle reading). If I accelerate again it goes up and then comes back down. If I am on the highway and going 100 km/h - 130 km/h the oil pressure gauge reads about 375 kpa (inbetween middle and top reading).
I had never noticed it doing this before, but I wasn't really looking either.
Is this normal? Shouldn't the oil pressure stay constant for the most part when driving? The oil pressure never drops below around 250 kpa. I don't know if this is from the recent oil change or what? Did they not put enough oil in? (I checked the dip stick and it looks fine) Just looking for some insight for you guys that are more "car know" than I.
Thanks.
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day
bluch is offline   Reply With Quote
Old 09-19-2009, 09:22 PM   #2
Darsh 007
Drives: 2010 Camaro - 2LT
I'll double check mine tomorrow and confirm for you. I was going "hmm" on my 3.5 hour drive from the dealer this week when I noticed a similar situation. Did a 'lil bit of research, and...
Basically, the pressure is a direct result of the combustion. Higher RPMs is forcing the oil through this system with greater force, so your pressure will go up.
I'm not a mechanical engineer, but it seems to be on par with expected behavior. Anyone else?
1100 = Preliminary Order: 5/8/2009
Cancelled by dealer (grr!): 7/2/2009
1100 = 7/16/2009 (awesome new dealer)
2000 = Accepted By GM: 7/25/2009
3000 = Accepted By Production Control: 7/29/2009
3800 = Produced: 8/31/2009
5000 = Delivered To Dealer: 9/14/2009
6000 = Woohoo!!!: 9/15/2009
Darsh 007 is offline   Reply With Quote
Old 09-19-2009, 09:25 PM   #3
ShnOmac
Sorry bluch im no help on this one....
ShnOmac is offline   Reply With Quote
Old 09-19-2009, 09:27 PM   #4
bluch
OH CANADA!
bluch's Avatar
i understand that the oil pressure will go up as you work the car's engine works harder.
i'm just wondering if it is supposed to fluctuate that much and go that high?
Old 09-19-2009, 09:30 PM   #5
ShnOmac
Hows the oil look on the dipstick when you pull it out? Does it seem like the correct weight?
Old 09-19-2009, 09:33 PM   #6
bluch
OH CANADA!
bluch's Avatar
the dipstick looks good. i checked it and it looks full and super clean...almost hard to see it is so clean
Old 09-19-2009, 09:36 PM   #7
ShnOmac
I know with our G8 it fluctuates but it never pegs out.... we need someone to go check their car!
Old 09-19-2009, 09:43 PM   #8
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Read my post from July. Mine started at 400 miles. Goes in this week for new senser.
How much for the oil change?
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 09-19-2009, 10:00 PM   #9
bluch
OH CANADA!
bluch's Avatar
$110
Old 09-19-2009, 10:30 PM   #10
lostinvt
Serial #589!
lostinvt's Avatar
Drives: 2010 2RS/SS
FWIW mine is pretty similar. When the engine is cold, any time the car accelerates or I even touch the gas the oil pressure pegs. Even after it warms up, it's very common (at least in my car!) for the needle to bury itself under acceleration....
Not sure if it's expected or not, but seems common in my car....
lostinvt is offline   Reply With Quote
Old 09-20-2009, 05:02 PM   #11
OUR72GTO
OUR72GTO's Avatar
$19.97 for the GTX @ Wal Mart and 8.95 for the cartridge at Lordco. Better than having some rookie lean all over my fenders. See if this changes any readings before GM monkies with it.
Old 09-20-2009, 06:08 PM   #12
DEW
Drives: Hoopdee
Absolutely normal, The oil pressure is a direct reflection of revolutions of the oil pump. RPM of the crankshaft increases, so does the oil pump resulting in higher oil pressure. Yuo should see some Harleys oil pressure at idle, almost 0.
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 09-20-2009, 06:14 PM   #13
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
There probably is a "high Pressure relief valve" to prevnt excessive pressure. Also there are 3 dual jets that squirt oil against the bottom of the pistons to keep them cool, which may require higher pressures.
zen is offline   Reply With Quote
Old 09-21-2009, 02:32 AM   #14
camarogolfguy
Camarogolfguy
camarogolfguy's Avatar
Drives: 2012 ssrs
Cool
Thanks.
Have you checked the oil level? I believe the LS3 takes 8 qts with filter change.
camarogolfguy is offline   Reply With Quote
BP Makes "Giant" Oil Find in Gulf of Mexico KILLER74Z28 General Automotive + Other Cars Discussion 1 09-02-2009 08:39 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
