![]() ![]() ![]() Drives: 2014 Camaro 2SS RS & Ground effects Join Date: Apr 2014
Has anyone heard of or seen a TSB for a Master Cylinder Reservoir and / or cap leak or weep on the 2014 Camaros? If so where can I get a copy? I could not find it.
I apologize to the admin ahead of time if I posted this in the wrong area
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 Last edited by Stewart; 12-24-2015 at 04:56 PM. |
![]() Drives: 2014 Camaro 2LT Deep Magenta Join Date: Apr 2015
I'm watching this, I had my slave cylinder replaced and I saw some weep around it..
I noticed mine is as well
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260 |
KNGTFALL
Drives: 2012 2SS 45th edition Join Date: Aug 2012
This has been an issue since day 1 not just the 14.
Wow, and they have not addressed the problem???
#6 |
![]() Drives: 2015 zl1 camaro Join Date: Jan 2015
I replaced the thin gasket in cap with Pt# 42072 Master Cylinder Gasket for the cap from advance auto . Problem fixed .
#7 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I had the master cylinder replaced per the TSB. Within 4 months it started leaking again. I Purchased the Dorman Master Cylinder gasket (Part# 42072) and there's not been one drop of fluid leak out of the cylinder since. I wouldn't waste your time with the TSB, just purchase the gasket and be done with it.
#8 |
Thank you hawk02 and blackbird15 I will be getting one Saturday morning. I agree it would be easier just getting the part then dealing with a service dept.
#9 |
KNGTFALL
They addressed the problem by replacing parts, but the cap is loose on the replacement parts as well. The gasket (above) seems to take care of this issue as it is a little thicker than OEM and allows the cap to seal.
#10 |
Thank you GVA 45TH 2SS I am going tomorrow ( Saturday ) and get the replacement gasket.
#11 |
old school chevy rodder
I have in the past seen on here Caps that have a slit in the center of the rubber seal that is on the cap........ Some kind of crappy manufacturing defect....
#12 |
I want to thank all that helped with this. I went this morning to Advanced Auto and picked up a Dorman Master Cylinder gasket (Part# 42072). I compared the OEM one to this one and what a difference. Not only is the new one thicker, it also seems to be made much better then the OEM one. After replacing the 2, which was surprisingly very easy, the cap fit a lot tighter. Now I have to get the cover I made to cover the bottle sand blasted and repaint it as the leaking brake fluid bubbled the paint near the fill. Thanks again, I knew I could count on the members of Camaro5 to help.
#13 |
^- so just purchase the cap and problem solved with the part numbers provided here? Or do I need a full replacement
#14 |
You use the OEM cap just the rubber gasket gets replaced.
