Old 12-26-2015, 07:16 PM   #1
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
S/C coolant reservoir install
My wonderful wife got me the Lingenfelter (Roto-Fab) coolant reservoir for a Christmas gift. I've been wanting one for a while and now that I have it, I'm a little unsure of the install process. The directions "assume you have already removed the stock airbox (easy plus already have Roto-Fab intake installed and will remove in about 1 minute) as well as the charge air cooler coolant hoses." I found a thread on here for draining the S/C coolant (located here) but am wondering if you guys who have done this before think this can be done without draining the system.
Any thoughts/recommendations/suggestions or better yet, some step by step instructions how to do it?
Thanks for the help guys.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 12-26-2015, 11:51 PM   #2
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
I installed mine without draining the whole system. Check out this thread here:
http://www.camaro5.com/forums/showthread.php?t=426286
jayno20 is offline   Reply With Quote
Old 12-27-2015, 12:06 AM   #3
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
http://www.lingenfelter.com/sites/lp...Kit%20v1.2.pdf
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 12-27-2015, 01:04 PM   #4
winterboy8
winterboy8's Avatar
I have the Lingenfelter directions, just wasn't sure if this could be done without draining the entire system.
Jayno, when you removed the hose from the pump, I'm assuming you clamped it. But, did any fluid make its way out of the pump once removed? I would guess you clamped the feed hose (the one not being removed) and when you removed the hose feeding the pump, you just drained it into a bucket or something.
Thanks for help/advice.
Old 12-27-2015, 01:05 PM   #5
jayno20
Go fast, please.
jayno20's Avatar
When removed from the pump I lost about half a quart of fluid.
Old 12-27-2015, 01:09 PM   #6
winterboy8
winterboy8's Avatar
Originally Posted by jayno20 View Post
When removed from the pump I lost about half a quart if fluid.
Cool, I have to get some fluid before I try this, but hopefully will be done before the week is out. Thanks again for the advice and the link.
Old 12-27-2015, 01:12 PM   #7
jayno20
Go fast, please.
jayno20's Avatar
You're welcome! It's all pretty easy.
Old 02-23-2016, 12:33 PM   #8
CamaroI
Drives: 2010 IOM Camaro
Is the reservoir still functioning well
CamaroI is offline   Reply With Quote
Old 02-23-2016, 12:37 PM   #9
jayno20
Go fast, please.
jayno20's Avatar
Last day I had it out it was fine. It's been in the garage for the last 2 months.
