Old 12-31-2015, 06:47 PM   #1
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
Question Threw a code today
Had the "engine light" come on today and went to Auto Zone to find out what it was. The tech ( ? ) put the computer thing on it and said it was a code for an Air sensor delay. He was kind enough to clear it for me and said that sometimes the weather has a lot to do with it. I do know that the temp here in NJ changed like crazy from yesterday to today. Need some input on this as I am not up on this to much.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 12-31-2015, 10:57 PM   #2
jdrop01
jdrop01's Avatar
Drives: 05 GTO
Did you get the code? That will help more as the code we can pull up and look at the troubleshooting.
jdrop01 is offline   Reply With Quote
Old 12-31-2015, 11:16 PM   #3
xrivera91
xrivera91's Avatar
Drives: 2015 Camaro 2ss
Go on amazon and spend the best 20 bucks of your life. An obd reader. It'll tell you the codes and let you clear them.
xrivera91 is offline   Reply With Quote
Old 12-31-2015, 11:20 PM   #4
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
+1
http://www.amazon.com/BAFX-Products-...=BLUETOOTH+OBD
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
Old 12-31-2015, 11:22 PM   #5
xrivera91
xrivera91's Avatar
Originally Posted by ghosted View Post
Haha that's the exact one I got. Too broke to do a tune for my kooks headers so I just throw this in clear the codes and keep it moving. I know it does other stuff as well but I haven't tried it out yet.
Old 12-31-2015, 11:26 PM   #6
ghosted
BCS Auto
ghosted's Avatar
I actually run a 10" tablet in my car and use Torque Pro to monitor all kinds of stuff, temperatures, sensor readings, etc. I also monitor my timing advance to see if I'm getting any pre-detonation, and use that info to stay away from gas stations with sub-par fuel.
I'm planning on building a 'carputer' with a touchscreen in a spare visor, and the brain in the dash, and will also run auxiliary gauges there for performance days. This will use the OBD port as well.
Old 12-31-2015, 11:31 PM   #7
xrivera91
xrivera91's Avatar
How do you have this all set up!? I would love to do something like that it sounds bad ass. Any pics?
Old 12-31-2015, 11:35 PM   #8
ghosted
BCS Auto
ghosted's Avatar
The Tablet just mounts to the right of my shifter with a custom-made bracket, but the whole carputer idea is still in the works. I've got the spare visors and the display, I just have to order the brain components and put it all together
Don't worry, I'll definitely be posting when I'm done with it! Though I'm easily distracted by a hundred other mods, so I bounce around a bit, but I promise you I'll get to it.
Old 01-01-2016, 03:27 PM   #9
Stewart
Stewart's Avatar
Thanks for the help. I did not get the code numbers (I should have) Will be looking into one of the scanners. hopefully I will not need to use it.
Old 01-01-2016, 04:07 PM   #10
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Drives: 2015 2SS/RS CV CE
Is the BAFX3127 the same unit?
http://www.newegg.com/Product/Produc...0H5-00Y6-00001
PDXSSCE is offline   Reply With Quote
Old 01-01-2016, 04:12 PM   #11
ghosted
BCS Auto
ghosted's Avatar
Originally Posted by PDXSSCE View Post
Most likely, yes.
Old 01-01-2016, 05:09 PM   #12
jwcassidy1969
Drives: 2018 red hot 1le
Have you addded a cold air intake or is it stock? Is it factory tuned and factory filter? Could be dirty filter or mass air parameters incorrect in tune (if not factory tuned) could just need mass air cleaned.
jwcassidy1969 is offline   Reply With Quote
Old 01-01-2016, 05:13 PM   #13
PDXSSCE
Yee-aay-ee!
PDXSSCE's Avatar
Most likely, yes.
OK, I found it's the same unit & refers to the UPC 859261003127.
Old 01-01-2016, 05:20 PM   #14
Stewart
Stewart's Avatar
I added a CAI about 8 months ago. I keep the filter clean ( once a month ) I will check the MAP How do you know if it is dirty? I mean will it be obvious?
