Old 01-03-2016, 10:20 PM   #1
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
lsa conversion question
im going to start a lsa conversion on my 1le in the next few weeks. what size is the stock upper pulley? how much will i end up with on stock pulley. ill be running the ls9 cam with LT heads and off road exhaust.
supergt99 is offline   Reply With Quote
Old 01-03-2016, 11:39 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
You'll want to install a 2 piece pulley now, trust me... 2.75 or 2.55...
I'm running the stock pulley but vvt ss1, ported heads with headers, cai and I'm at 590 RWHP but each car varies..
-Don
747 RWHP 794 RWTQ
Old 01-04-2016, 01:02 AM   #3
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
stock pulley? 91octane?
570whp ish
that's where im at and you described a similar setup to mine. I don't have headwork though.
your sig says NF Cam in your 1LE. why not keep that, the LS9 is downgrading.
I wish I had upgraded the pulley at least one size.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 01-04-2016, 12:42 PM   #4
hammdo
hammdo's Avatar
Ls9 cam is good for boost and I don't think the valve springs need to change if stock are still on but, if you can, I'd go with a BTR PD stage 2 or 3 cam. If the NF is an n/a cam, might be a good reason to change..
-Don
747 RWHP 794 RWTQ
Old 01-04-2016, 12:45 PM   #5
hammdo
hammdo's Avatar
BTW, more power does not necessarily mean better ets... ;o)
-Don
747 RWHP 794 RWTQ
Old 01-04-2016, 11:53 PM   #6
ilir14
ilir14's Avatar
Drives: Camaro ss 1le
[QUOTE=hammdo;8821572]You'll want to install a 2 piece pulley now, trust me... 2.75 or 2.55...
+1
ilir14 is offline   Reply With Quote
Old 01-06-2016, 07:23 AM   #7
supergt99
supergt99's Avatar
I'll look into swapping the pulley now.
I didn't swap the night fury cam out yet. I think I'm gonna leave it in and give it a try. I love the idle.
Old 02-13-2016, 01:16 PM   #8
supergt99
supergt99's Avatar
Still thinking about the cam. Is 600rwhp possible with ls9 cam and 2.75 pulley?
Old 02-13-2016, 02:17 PM   #9
hammdo
hammdo's Avatar
2.55 and injectors may get you close.. 580s to 590s. BTR PD stage 1 and 2.55 had done it or real close...
-Don
747 RWHP 794 RWTQ
Old 02-13-2016, 03:23 PM   #10
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I bet you will break 600whp using the night fury cam and a 2.5 upper
Stock upper is 2.95
ttshovel is offline   Reply With Quote
Old 02-13-2016, 03:35 PM   #11
ilir14
ilir14's Avatar
I have BTR stage 1 and 2.75 pulley pushing 650+ rwhp, it will definitely get you over 600
Old 02-17-2016, 10:56 AM   #12
jose1003
jose1003's Avatar
Drives: 2010 Camaro 2SS Cyber Gray
What pulley would you all go with, I think adm sells one of the best pulley
I'm also doing an lsa conversion, I only have cat back and ADM intake, with lsa conversion can I get up to 550hp total (not rwhp)?
Should I also change pulley
jose1003 is offline   Reply With Quote
Old 02-17-2016, 06:50 PM   #13
hammdo
hammdo's Avatar
Yes, pulley now before installing -- 2.55 you'll be glad you did.. You will need injectors and ZL1 Fuel Pump and ADM FPCM. If you don't want to add all of that, stock is good -- I'm right @ 600 RWHP with just 6 PSI boost -- of course, I do have other mods ;o) -- as you may already know....
-Don
747 RWHP 794 RWTQ
