Old 01-07-2016, 04:48 PM   #1
adnarim210
Drives: 2012 camaro 2LS
NEED HELP! BAD VIBRATION
okay I need help with a major problem I am having. I own a 2012 Camaro 2LS (automatic) and I had some work done on it. I have 3.91 gears, gforce axles and a true trac installed. Since all these changes were done the car had some vibrations but not something noticeable. Today, the car started shaking violently and I'm not sure if its the rear end or something else. Has anyone else dealt with this same problem?
adnarim210 is offline   Reply With Quote
Old 01-07-2016, 05:09 PM   #2
TX_ED_SS
TX_ED_SS's Avatar
Drives: 2010 2SS/RS Inferno Orange
Can you be a little more specific? Is the steering wheel shaking? At what speed does this violent shaking happen? Does it feel like the front end or is it coming from the rear? How long ago were these mods done? First thing I would do is get up under the rear of the car and check for anything that may be lose.
U.S. Army Retired
TX_ED_SS is offline   Reply With Quote
Old 01-07-2016, 05:18 PM   #3
adnarim210
the steering wheel isn't shaking but its shaking is coming from the rear. Also, it shakes at all speeds. I did the rear end in august of 2015. I was thinking about checking under the car tomorrow morning to see if anything is loose. I'm really scared to drive it :(
Old 01-07-2016, 06:14 PM   #4
TX_ED_SS
TX_ED_SS's Avatar
Good call on not driving it. You could do some serious damage or possibly wreck the car. If it's happening at all speeds I'd check your axles and driveshaft then move on to all the rear suspension mounts. Take your phone with you under the car and snap some pictures of any suspicious areas and post them. There are many folks here that will be able to point you in the right direction. Again, don't drive the car until you get this figured out.
U.S. Army Retired
Old 01-07-2016, 06:41 PM   #5
bosco200
Vet. USMC Machine Gunner
bosco200's Avatar
Drives: 2010 2SS Black with red stripes
Sounds like a ujoint problem, I had a truck with a bad ujoint and it shook really bad when I hit 30mph
bosco200 is offline   Reply With Quote
Old 01-07-2016, 08:11 PM   #6
adnarim210
thanks guys ill be posting pictures in the morning once I check everything in the rear and stuff. luckily I have my truck if I need to do any errands and running around lol
Old 01-08-2016, 07:03 AM   #7
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
This may sound silly, but have you checked to see that all of your wheel lugs are properly torqued?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 01-08-2016, 10:37 AM   #8
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
Take it back to the shop that did the work.
It could be many things, but some of them could be catastrophic if you keep driving it.
paul84043 is offline   Reply With Quote
Old 01-08-2016, 01:24 PM   #9
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
+1 start with the simple stuff first .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 01-08-2016, 01:29 PM   #10
ELIC1
Drives: black and silver
ASK DADDY HE SHOULD BE ABLE TO HELP YOU OUT
ELIC1 is offline   Reply With Quote
Old 01-08-2016, 02:53 PM   #11
dmginc
dmginc's Avatar
Drives: In Circles
+1
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 01-08-2016, 02:59 PM   #12
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
My rear diff. went out in 2013 causing a pretty violent shake. Did you get a chance to check it out yet?
justjoshin is offline   Reply With Quote
Old 01-08-2016, 04:34 PM   #13
crowejim
crowejim's Avatar
Drives: 2015 2LT RS Coupe
Simple things first: missing wheel weights, bad tire, loose lugs, u-joint. Good luck.
Hmmm... Possibly a mid-life crisis.
crowejim is offline   Reply With Quote
Old 01-08-2016, 05:33 PM   #14
adnarim210
Lol I do not need daddy's help. My dad taught me all I know and I found my problem.
