![]() Drives: 2010 Camaro SS Join Date: Jun 2015
Texas Speed Camshaft Package
https://www.texas-speed.com/p-260-ts...t-package.aspx
Thinking about camming out my Camaro and encountered this package when I began to shop around. Seems like a decently priced package. Would allow for AFM/DOD delete and it appears I can keep my stock stall. Does anyone have any experience with this cam package (I'd be interested in VVT-4 cam). HP gains, additional items needed, compatitibility? If I'm correct in understanding, this would essentially convert the L99 (which I have) to an LS3 with removing AFM. I'm a noob so correct me if I'm wrong. Anything would be helpful for me! Thanks! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: pleather and Chiclets Join Date: Mar 2012
It takes out AFM like you want but leaves the vvt from L99.
Not sure that cam is for a stock torque converter
![]() ![]() Drives: 2015 2SS/RS/1LE Join Date: Feb 2015
I believe you also need a phaser limiter with that cam as well. Call and talk to the Texas speed guys. They set you up right. I believe they are also now offering their cams on 8620 cores. I highly recommend going that route. It's a better steel.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports. |
Drives: 2010 2SS/RS Join Date: Jun 2009
Vvt-4 you cannot keep stock stall.
The problem with these cams is they won't tell you the specs. I bought the VVT-2 years ago when it was one of a few vvt cams to choose from and I have no idea what the specs are other than one forum i found it posted (which could be incorrect). |
![]() ![]() Drives: 2016 2SS coupe 2015 3LT Stingray Join Date: Aug 2012
I know they dont post them but I saw the camcard on a tsp vvt 4 cam and it was a 235/239
Ported intake manifold and throttle body kooks 2" headers no cats
#6 |
Would be nice to have the cam spec card but it's been so long I cant get it from TSP or tuner.
#7 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
I would recommend contacting Brian Tooley Racing, he can set you up with the correct cam and necessary components.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
#8 |
I personally went to Ryan at GPI performance... I am very happy with the power curve that the SS1 and VVT gave the car... If you are chasing Dyno numbers and peak HP then there are better cams. I looked at what the SS1 gave my car in the lower RPM range as compared to the SS2 or SS3. Both the SS2 and SS3 made more "peak" power, but gave it up on the low end. I am not chasing 1/4 mile times, the SS1 makes more usable power.
Looking at the LS3 / CAM dyno numbers that others are posting compared to my L99 with VVT numbers, I can't see why you would give up the VVT, unless you are building a very high RPM engine that will do nothing but run the 1/4 mile.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
#9 |
![]() Drives: 2012 Camaro 2SS - black Join Date: May 2018
Did you do it?
Did you ever end up getting this package? I found it as well and am strongly considering it since they have the whole VVT Cam package with DOD/AFM delete for like $1200.
If you did go through with it, as well as keeping the VVT, did you have to go with any of the custom add-ons, like longer pushrods or any of the other optional equipment (obviously the DOD delete kit). This would be a major project for me, a caliber project I've never before gotten into, so I want to make sure I'm getting everything I need. |
