Old 01-08-2016, 01:57 PM   #1
Jason@Phastek
Jason@Phastek's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek
Thumbs up B&M Deep Transmission Pan for 6L80
Just wanted to put this video up for anyone needing an more information on the B&M Racing Cast Aluminum Transmission Pan. PT#70391
B&M Racing Camaro Transmission Pan Increases the Life of your Automatic Transmission for your 2010-2015 Camaro SS 6L80 L99
The B&M Camaro SS (6L80 Automatic Transmission) Cast Aluminum Deep Trans Pan was designed to add 1.8 US quarts of additional fluid capacity to the 6L80 transmission. It boasts an over 30 percent improved cooling efficiency over the stock transmission pan by using a proprietary K-Alloy cast aluminum with internal and external cooling fins for increased surface area and heat transfer. The pan includes a magnetic drain plug, temperature sensor port, stock magnet hold down, and stainless steel mounting hardware. The cooling fins of the pan sit just 3/4 In. lower than the stock pan to take advantage of cooler air passing underneath the vehicle. Heat is the number one enemy to any automatic transmission and this B&M Cast Aluminum Deep Pan will help keep heat under control.
Features and Benefits:
Cast K-Alloy Aluminum
CNC Machined Internally and Externally Finned
Magnetic Drain Plug
Temperature Sensor/External Cooler Port
Specifications:
Added Capacity: 1.8 US Quarts Cooling
Efficiency: 30% over stock Package
Contents: Pan & Hardware (mounting bolts & plugs) - requires gasket, filter, and magnet
Pan Hang Over Stock: 3/4 inch
Pan Material: K-Alloy SP (Proprietary Aluminum Alloy)
Jason@Phastek is offline   Reply With Quote
Old 01-09-2016, 12:05 AM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I would highly recommend Every Camaro owner with the 6 speed Auto Transmission upgrade to the B&M trans pan. More fluid = lower temp = longer life = better performance>
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 01-09-2016, 12:07 AM   #3
LSX Camaro
LSX Camaro's Avatar
Here is mine.
Old 01-09-2016, 12:08 AM   #4
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Btw these don't work in the ZL1 ... Ask me how I know lol
Crash76 is offline   Reply With Quote
Old 01-16-2016, 07:10 PM   #5
flyer08
Drives: 2010 2SS/RS
Already have the pan, shoot me a pm on B&M dip stick
flyer08 is offline   Reply With Quote
Old 02-01-2016, 11:08 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Got both pan and dip stick. Glad I did that...
BTW, vid is not working...
-Don
747 RWHP 794 RWTQ
Old 02-03-2016, 11:14 AM   #7
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
I went with the Moroso pan on my pain in the ass 6L80 but it doesn't have the dipstick option....
RaiderSS is offline   Reply With Quote
Old 02-04-2016, 01:29 PM   #8
Tech@B&MRacing
Tech@B&MRacing's Avatar
Drives: 2016 Camaro SS
The B&M Transmission Dipstick (#22168) for 10-15 Camaro installs into the case of the transmission itself and is compatible with any transmission pan that you have on your 6L80.
Tech@B&MRacing is offline   Reply With Quote
Old 02-04-2016, 02:34 PM   #9
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
How hard is the install for the dip stick?
camarosspower is offline   Reply With Quote
Old 02-05-2016, 12:48 PM   #10
Tech@B&MRacing
The install is pretty straightforward, and no modification is required. You simply remove the fill plug, route the dipstick and mount it. Click here to view the installation instructions.
Old 02-06-2016, 10:27 PM   #11
Crash76
Team 913
I put a dipstick in my 6L90 I ran it from the driver side to the insert on the transmissions right side...
6l80e, b&m, l99, phastek, transmission
