Old 01-08-2016, 02:35 PM   #1
vicnkathy
Drives: 2014 Subaru Forester Turbo
WTB Z28 Exhaust Manifolds
Looking for a set of manifolds and or cats. I want to do a before and after test on my ZL1 to see if any factory tune power can be had. PM me with what you got.
vicnkathy is offline   Reply With Quote
Old 01-08-2016, 04:32 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I bought what your looking for, an most of the Z guys are holding their removed parts pretty close. I hope you can find the what your looking for it took me about 2-3 months to get everything, I'm hoping for some HP on my LS3 not a ton though...
Old 01-09-2016, 06:28 AM   #3
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
You may already know, but the manifolds/cats do not terminate at the point as your factory ZL1 exhaust system. (They don't line up). You will need to either get the complete system or do some fabricating.
Old 01-09-2016, 09:53 AM   #4
chimazo
Drives: 2016 Ram
Don't know if you're aware that the manifolds are available from GM and are not restricted. P/N 19302762 ~$900
chimazo is offline   Reply With Quote
Old 01-09-2016, 11:33 AM   #5
1leNPP
Drives: 1LE , 1SS , NPP
These are C.A.R.B. legal will fit your cats http://www.phastekperformance.com/20...es-1812sjt.htm
1leNPP is offline   Reply With Quote
Old 01-09-2016, 01:37 PM   #6
vicnkathy
Fabricating is not an issue. My best friend owns a muffler shop.
Old 01-09-2016, 02:43 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The exhaust pipe is also a different dia an yes a good muffler shop will be your friend....
Old 01-09-2016, 02:44 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Headers
I got half that in my factory headers from a member just be patient you'll find a set.
Plus the factory set will look better and are also a Tri-Y design..
Old 01-09-2016, 03:03 PM   #9
vicnkathy
Exactly my point. An aftermarket set are not a consideration. My goal was to make as much power while using factory parts. Will do a before and after dyno and post my install and dyno results.
Old 01-09-2016, 04:34 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Really interested in how this turns out because I have a header an cat set just waiting for time an a little warmth to install, my only concern would be the width of inside to inside where the cats to stock exhaust connect an how much fabrication will be required. I have a SS with LS3 an I'm pretty sure the ZL1 an SS are the same but far as the Z/28, Callaway Chris measured for me and said its 18-3/4 from inside to inside on a stock Z/28 setup...
Old 01-12-2016, 07:34 PM   #11
vicnkathy
Ttt
Old 01-14-2016, 02:57 PM   #12
vicnkathy
Responded sir. Thank you
Old 01-15-2016, 05:56 AM   #13
vicnkathy
Still looking guys. Let me add though I'm not looking to spend $900
Old 01-15-2016, 07:36 AM   #14
Z/28Dan
Z/28Dan's Avatar
Drives: 2013 HWSE Indy Festival #26
$391.00 each at GM Parts House:
http://www.gmpartshouse.com/oe-gm/12652399
Brand new of course. Not sure where the 900.00 came from, but that is way over market for a used set.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
