Old 01-12-2016, 12:43 PM   #1
Gangsta
Gangsta's Avatar
Drives: 2013 Convertible 2LT/RS
Question Quick Question
Does the door glass differ between the coupe and the convertible ?
if you own a convertible can you please submit some picture of the door glass shape, both driver and passenger side.
i believe mine was changed before buying the car and they put on the normal coupe glass and that causes water leak because its not a perfect fit
Gangsta is offline   Reply With Quote
Old 01-12-2016, 04:38 PM   #2
PROZ11
PROZ11's Avatar
Drives: 2012 RS/2SS, 69 ProStreet Camaro
According to this they are different. I assume the coupe glass is taller since convertibles usually have shorter windshields tan a coupe of the same model.
http://www.gmpartsnow.com/auto-parts...lass-door-scat
PROZ11 is offline   Reply With Quote
Old 01-12-2016, 06:26 PM   #3
Gangsta
Gangsta's Avatar
There seems to be two different part numbers for the glass. i assume what you're saying is correct
but i need to find out which one is on my car now since the previous owner had to change it after a car accident. i believe they got him the coupe glass
camaro, door, glass
