Old 01-12-2016, 11:52 PM   #1
96_2010_CAMARO
96_2010_CAMARO's Avatar
Drives: 2012 SIM Camaro 2SS/RS , 2010 Tahoe
Send a message via MSN to 96_2010_CAMARO
D1S led conversion
Hello , i saw these on Amazon and they have the same bulb size as our rs headlight and I'm seeking experts advise before I pull the trigger on them , any reason that won't make them work ? ( want them cause they don't worm up unlike the hid)
Thanks !
2012 2SS/RS silver ice metallic camaro
96_2010_CAMARO is offline   Reply With Quote
Old 01-13-2016, 04:14 PM   #2
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Definitely interested to see how these work
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 01-13-2016, 05:00 PM   #3
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS, 2010 Camaro SS
Interesting...
I dont see a problem since you will just get the power signal from the factory connector. I would not use any HID parts, so the ballast would just stay in place. Other then that do see an issue.
Thank you,
Ricardo
Sales@Phastek is offline   Reply With Quote
Old 01-13-2016, 06:07 PM   #4
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
I have LED headlights and they look great. http://www.amazon.com/OPT7-Headlight...ywords=h13+LED
The one's I got don't have the same Wattage as yours.
btw. Sig pic is from before I installed those.
HyperV117 is offline   Reply With Quote
Old 01-13-2016, 08:44 PM   #5
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
Will these increase the output and overall brightness compared to the stock rs light outpus?
Sent from my Nexus 5 using Tapatalk
C-redfly is offline   Reply With Quote
Old 01-15-2016, 07:16 AM   #6
aland12345
aland12345's Avatar
Drives: 2016 Bright Yellow Camaro vert
LED Headlights?
Well I've tried two different sets. First set was flat with Low beam LED on Top and High beam on bottom. Can't say I was a fan... Problem is stock LT reflectors (non RS) are designed for a filament that shines 360 degrees. The LED while brighter on low beam only uses something less than 180 degrees. I wasn't happy with the pattern at all. I just bought a set of diamond shape LED's last night (two low beam and two high beam Leds on each bulb) it looks better but the jury is out until I have time to align them on a dark road I like the 5/6000 K light. I like the way they snap on similar to a HID. Just not sure about beam pattern and glare to oncoming drivers....
aland12345 is offline   Reply With Quote
