![]() Drives: 2013 Camaro ZL1 Join Date: Nov 2015
APR Carbon Fiber front splitter install question!!
Ok So I got the APR front splitter for Christmas. I took the front bumper off a few days ago to start the install. I searched here and another member recommended cutting out a template and bolting it to the front so that all your holes will line up. Did that, got it done, great. My question is which side of the splitter do I start drilling from? This is not a cheap mod and the last thing I want to do is crack it in some way. Do I drill from the glossy top or the unfinished bottom? The wife is tired of seeing the front bumper in the finished basement so I need some help asap!
13' Black ZL1 M6- Rotofab CAI, M/T Street Comps, black taillight bezels, black badges, APR CF front splitter
![]() Drives: 2015 zl1 Join Date: May 2015
Put tape around your holes in case your bit walks it's will help with scratching and as far as drilling I would start from the side you will see because sometimes the drill will chip or splinter coming out the other side.....might want to let someone else that has carbon fiber experience chime in to be 100%. Good luck post up pictures when you get it on I would like to see it.
Drives: 2014 Subaru Forester Turbo Join Date: Aug 2013
It's not pre drilled?
![]() Drives: 2014 ZL1- Summit White M6 Join Date: Aug 2014
It's still a surprise to me they don't pre drill the holes for their customers. After all when we purchase the splitter from APR we buy one exact spoiler for the exact model of car we will be putting it on.. If it was a universal fit then I can understand the drilling, but it's a ZL1 specific spoiler. The simplicity and peace of mind of a bolt on and go spoiler would well be worth another $100 atleast to us customers I'm sure
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
One of the toughest mods.
#6 | |
aerosportconcepts@gmail
![]() Drives: '15 1SS-RS/1LE (RRM) Join Date: Dec 2011
Let me know if i can help anyone out. Kurt
#7 | |
![]() Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
#8 |
![]() ![]() ![]() Drives: 2013 ZL1-Victory Red-Auto Join Date: Mar 2010
I drilled the holes from the bottom and had no issues at all.
#9 | |
Ya. The ZL1 is the easiest to install. Unlike the 1LEs the ZL1 has a couple dozen factory screw locations that can be reused. The 1LE Splitter need to have Fasteners to hold it on. Screws just don't hold up in the Plastic Splitter over time. I've found that the ZL1 Front assembly is so strong you really don't need the Support Rods either. They are more aesthetics then anything. Sent from my XT1254 using Tapatalk
#10 |
![]() Drives: 14 ZLONE Join Date: Dec 2015
i have the apr splitter in my garage right now. Although the "no pre-drilled hole" deal kind of sucks, it also has its benefit in that you can adjust how far out you want the splitter to stick out. My bumper is coming off tomorrow...tho i am pretty sure it doesnt need to to install this. I used the box they shipped in to cut out a splitter template then hold it up and rub with a pen against the bolts holes to get where the bolts line up. i will not be sticking the splitter out very far and wont be using the support rods.
#11 | |
![]() Drives: 2018 ZLE Join Date: Jul 2014
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Join Date: Oct 2014
Love my APR splitter!
#13 |
hey guys i did not get any instructions with my splitter...finally got the bumper off...i see 18 screw holding the OEM one. I only received 12 bolts...what goes where? thanks split
#14 | |
![]() Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
![]() Quote:
I am going to install one of these splitters on my car. Do we reuse the existing holes? Do you supply longer bolts to install? Thanks, Sam. |
