Old 01-13-2016, 05:32 PM   #1
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Rod bearings have you seen this?
Like the title says. Have any of you guys seen this? My bearings are bad on the rod side of the bearing. Not the crankshaft side. Only two bearings were like this, the rest of the motor looked spotless. Ordering all the rebuild parts this weekend. But just wondering if any of you experts out there could tell me the cause of this.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-13-2016, 06:10 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Are you refering to the staining? It can be an indication of bearing movement. What does the back of the bearing look like? and what do the other rods look like?
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 01-13-2016, 06:20 PM   #3
1KillerSS
1KillerSS's Avatar
I thought I had a picture of the backside of the bearing, Ill get it posted soon. Other than those two bearings, the rest were spotless. The whole engine was spotless.
Build thread
Old 01-13-2016, 06:26 PM   #4
White_SS/RS
Drives: 14 1LE
Kinda wierd its just the one and the rest are spotless. May want to have the sizing checked on that rod and a few others for comparison.
LMS Engineering
Old 01-13-2016, 07:13 PM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I'll post a picture shortly, the cap had a lot of heat in it. The back side of the bearing shows a large amount of wear but as stated, the crank side of the bearing was not affected. There were no shavings to be found in the pan either.
ttshovel is offline   Reply With Quote
Old 01-13-2016, 08:22 PM   #6
1KillerSS
1KillerSS's Avatar
There were two bearings that were like that, sorry for some reason in my previous posting, I spelled two, as "to" This was a factory assembly.
Build thread
Old 01-13-2016, 09:01 PM   #7
ttshovel
ttshovel's Avatar
I just looked through them all and the bottom of the bearing looks just like the cap. Maybe it was a power related issue?
Old 01-14-2016, 03:09 PM   #8
1KillerSS
1KillerSS's Avatar
A couple of people have mentioned, oil starvation. My parts list will include a high volume oil pump. Hoping when its all said and done, with the quality parts were going to put into the engine, that I can drive it worry free, without wondering how long it will last. LOL
Build thread
Old 01-14-2016, 07:17 PM   #9
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
Uneven bearing wear due to misalignment can also result if the*crankshaft*journals are not true. To check the roundness of the crank journals, measure each journal's diameter at either bottom or top dead center and again at 90 degrees either way. Rod journals typically experience the most wear at top dead center. Comparing diameters at the two different positions should reveal any out-of-roundness if it exists. Though the traditional rule of thumb says up to .001 in. of journal variation is acceptable, many engines cannot tolerate more than .0002 to .0005 in. of out-of-roundness.
To check for taper wear on the journals (one end worn more than the other), barrel wear (ends worn more than the center) or hourglass wear (center worn more than the middle), measure the journal diameter at the center and both ends. Again, the generally accepted limit for taper wear has usually been up to .001 in., but nowadays it ranges from .0003 to .0005 in. for journals two inches or larger in diameter.
The journal diameter itself should be within .001 in. of its original dimensions, or within .001 in. of standard regrind dimensions for proper oilclearances*with a replacement bearing. If a journal has been previously reground, there is usually a machinists mark stamped by the journal. A 10, 20 or 30 would indicate the crank has already been ground to undersize, and that further regrinding may be out of the question depending on how badly the crank is worn.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 01-14-2016, 07:59 PM   #10
Unreal
Drives: 2006 Z06
Since it was a factory untouched motor, hard to believe it was a regrind issue or even a out of spec crank.
Nick
Corvette Z06 -1200ish rwhp
Old 01-14-2016, 08:48 PM   #11
pancherj
Drives: 2010 Camaro SS
Detonation would be my guess...but I would think you'd see evidence on the Pistons also.
pancherj is offline   Reply With Quote
Old 01-14-2016, 08:49 PM   #12
1KillerSS
1KillerSS's Avatar
Pistons are spotless, tune was dead on.
Build thread
Old 01-14-2016, 09:35 PM   #13
ecreps
Drives: 2014 1LE, 1996 z28
Which cylinders did the issue present itself on?
ecreps is offline   Reply With Quote
Old 01-15-2016, 09:51 AM   #14
UNRIVALED SS
UNRIVALED SS's Avatar
Send a message via Yahoo to UNRIVALED SS
Details please.
Which 2 cylinders? (#)
Power adder?
Oil weight?
My first opinion is detonation causing severe pressure on the bearing rod side as it makes the power stroke. Could be caused by a lot of things. Example , intake leak , but only under high boost. AFR looks good tuning because the other 6 are good. Need more info. If the 2 cylinders are on the same side and joining then it's a indicator versus opposite sides on the same journal or separated all together. I'm very interested in as much detail as you can offer.
UNRIVALED SS is offline   Reply With Quote
