Old 01-17-2016, 12:58 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Nitrous noob
Ok so I've been kicking around running a small 75 shot on my lsa converted SS. Just after cooling everything down and some added power. Would I be ok with just a basic wet kit or do I need everything like the timing retard box? Yes the car will be retuned.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-17-2016, 06:24 AM   #2
2010_camaro
If I run nitrous should I keep my meth kit?
Old 01-17-2016, 10:07 AM   #3
flyer08
Drives: 2010 2SS/RS
If you're only going to do a small shot why not just stick with meth?
flyer08 is offline   Reply With Quote
Old 01-17-2016, 05:59 PM   #4
2010_camaro
75 shot makes more power over meth. I didn't see hardly any gain with meth.
Old 01-17-2016, 06:08 PM   #5
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Continue to spray meth. You won't be on the bottle all the time so the added power and safety off the bottle from the meth would greatly benefit you
ttshovel is offline   Reply With Quote
Old 01-17-2016, 11:07 PM   #6
2010_camaro
Idk what a good safe shot would be on a stock bottom end. I'm already at 10psi making 650whp
Old 01-18-2016, 01:00 AM   #7
ttshovel
ttshovel's Avatar
If I were you, I would call several nitrous vendors for their thoughts. Nitrous outlet was very informative the last time I spoke with them. It also wouldn't hurt to call a couple shops that tune a lot of zl1s for their opinions as well
Old 01-18-2016, 06:41 AM   #8
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
+1 on continuing to use meth. Stock bottom end will be good with a 75 shot.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
