Old 01-17-2016, 11:29 PM   #1
Germy2011
Drives: 2015 Summit White Camaro LS Coupe
Moving Thud In The Back Of My Car
Hi,
I bought my 2015 Camaro LS Coupe last week. It was used with 2900 miles on it and had a clean carfax. If anybody remembers, I talked about never driving fast. After a while I decided to "Romping My Engine for Once" lol previous thread.
I noticed on the streets, when I shift. When my car has a good jolt of power. I hear a thud in the back. I kept hearing it frequently. I can add more description tomorrow when I drive to Work.
Today, I heard it again. When I parked. I thought ehh its my jack or my spare tire. I decided to just check in the back. The ****ing battery is in the back lol. That crazy I never knew that lol. But my battery is tightened down, so its not moving. It was too dark to check under the car, but do I even have a spare tire?
My real question, Has anybody every heard this thud in the car when you shift?
sincerely,
Germy2011
Germy2011 is offline   Reply With Quote
Old 01-18-2016, 12:42 AM   #2
Jason1831
Drives: 2015 Chevy camaro
I hear it in my 2015 LS also. Let me know if you find out. I hear it at a stop also.
Jason1831 is offline   Reply With Quote
Old 01-18-2016, 12:49 AM   #3
MoeFaux
Drives: 2015 Camaro LS
I think its the gas sloshing in the tank.
MoeFaux is offline   Reply With Quote
Old 01-18-2016, 08:10 AM   #4
Germy2011
That very well could be, because I drove this morning, couldnt hear it. Plus I only have 1/4 tank. Ill dig up a little more research. Maybe some guys will jump on today and read and chime in. Happy Monday guys!
Germy2011
Old 01-18-2016, 10:13 AM   #5
The Dutchman
Drives: car
Trunk monkey.
The Dutchman is offline   Reply With Quote
Old 01-18-2016, 11:36 AM   #6
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
It's a bowling ball left in the trunk or back seat by the previous owner.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 01-18-2016, 11:42 AM   #7
The Dutchman
Drives: car
Previous owner may have been in the mafia.
Old 01-18-2016, 11:56 AM   #8
BadSport340
BadSport340's Avatar
Drives: 2014 Camaro LS, 1973 Dart Sport 340
My car makes a clunk sound when I press in the clutch sometimes at low speeds. It's normal and is caused by slack in the drivetrain when you press in the clutch.
If you're cruising along in first gear, foot OFF the clutch pedal, and you can give it throttle and it causes a thud/clunk noise then that might be a problem. But if it's just when you press in the pedal while coasting or something, that's normal and you shouldn't worry about it. This will be more apparent at lower speeds such as the 1-2 shift or when you're in first gear and you come to a stop.
BadSport340 is offline   Reply With Quote
Old 01-18-2016, 02:27 PM   #9
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Originally Posted by Germy2011 View Post
Hi,
sincerely,
Germy2011
If you found the ****ing battery, but did not move a spare tire out of the way to get to it, then you do not have a spare tire. If you see a nail in the road, swerve.
Regarding the thud, I occasionally hear it when I am rolling to a stop, when the tank is between 1/2 and 3/4 full. However, I do not hear it under acceleration (or shifts), as engine/ road noise out- holler the sloshing sounds... wondering if it's even a u-joint with a little too much play in it?
Scalded Dog is offline   Reply With Quote
Old 01-18-2016, 03:38 PM   #10
Pete M
9 Year USMC Vet
Pete M's Avatar
Drives: 2014 1LT black on black
Let your Mother in Law out of the trunk..Of course, by this time you're pretty much screwed either way.
A lot of stuff done so far to make it look better and be more fun to drive.....
Pete M is offline   Reply With Quote
noise, shifting, thuds
