Old 01-19-2016, 09:27 AM   #1
Tjclark
Drives: 2010 V6 RS
Service Stabilitrak Message
Hello all,
I was wondering if any of you have ever had this message appear. If so, what caused it for you and how did you fix it?
I am just trying to get a few ideas on what could be causing this.
Thank you!
Tjclark is offline   Reply With Quote
Old 01-19-2016, 09:33 AM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Appeared on my wife's truck on her first trip after a two week vacation. Never came back so I attribute it to a momentary low voltage somewhere in the circuit, on start-up.
If it persists, look for damage to the speed sensors or related wiring on the wheels.
Rock-It Man is offline   Reply With Quote
Old 01-19-2016, 09:58 AM   #3
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Misfires can cause this to appear, some have found loose plug wires after adding headers or working under the hood.
MMC is offline   Reply With Quote
Old 01-19-2016, 02:11 PM   #4
djpelosi
djpelosi's Avatar
Drives: 2010 Camaro 2SS/RS
Run a code scanner and see what it's throwing. This will likely tell you the cause. AutoZone will do it for free.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers
3" Full exhaust w/ Off-Road H-Pipe
Bo White Ported Throttle Body
Hurst Short Throw Shifter
Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires
Build Thread
djpelosi is offline   Reply With Quote
Old 01-19-2016, 02:35 PM   #5
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Got a throttle controller installed? Those will cause it sometimes also.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 01-20-2016, 11:00 PM   #6
Tjclark
Drives: 2010 V6 RS
Ill have to look into the loose wires. Thanks for all the suggestions!
Old 01-21-2016, 03:13 AM   #7
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Wrong!
Eddiefuzz is offline   Reply With Quote
Old 01-21-2016, 11:21 AM   #8
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
Originally Posted by Eddiefuzz View Post
Wrong!
Prove me wrong?
Old 01-21-2016, 11:28 AM   #9
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
Wrong!
Umm yeah, VTC can cause that. I know, it happened to me.
Sent from my campfire using smoke signals
Superman09 is offline   Reply With Quote
Old 01-23-2016, 11:02 AM   #10
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
I have a 2010 SS which I still had the original battery. It would sometimes turnover very slowly and when this happened the stabilitrac light would come on and the car would run like crap. I would have to turn off the ignition and let it sit for a minute or so and then fire it up again which resolved the problem. I've since got a new battery and it hasn't happened at all.
gnturboray is offline   Reply With Quote
Old 01-23-2016, 02:43 PM   #11
speedygonzales
speedygonzales's Avatar
Drives: 99 z71, 2012 2SS
Older batteries (beyond 4 years, you're on borrowed time) can and will cause "brownout" conditions to the ECM. When in the "brown" condition, anything can happen.
If you have a battery that could be older than 4 years old, it should be suspect. Particularly in cold weather.
And where is Mr. Fuzz with the rebuttal? He is wrong by the way.
Fix your garage pics so we can see them
speedygonzales is offline   Reply With Quote
Old 01-25-2016, 11:15 PM   #12
derklug1
derklug1's Avatar
Drives: 2016 GT350
The Stabilitrack system is too complex to just guess and replace components. You need at the very least to have codes run. If there is no CEL, chances are that the problem is only in the Stabilitrack. So, you have the wheel speed sensors, steering angle sensor, yaw sensor, brake input, power supply, etc., etc.
"Life is hard, it's harder if you're stupid" John Wayne
derklug1 is offline   Reply With Quote
Old 08-22-2019, 08:37 AM   #13
JooktheSnooke
JooktheSnooke's Avatar
Drives: 2010 camaro ss
so im having this problem too where the message is up and all traction lights on the dash are on. no CEL. did a lot of work to the car recently. what do you guys think it could be? the battery was the original so just put a new battery in yesterday.
2010 Cyber Gray Metallic 2SS/RS LS3 6 Speed -- Rotofab CAI | Stainless Works Longtubes w/ high flow cats | Muffler Delete | TSP 229/244 stage 2 cam| TSP .660" Spring Kit | TSP CNC Ported Heads | Mulling high volume oil pump | PTB | Trunnion upgrade | Hurst short throw shifter | Elite Engineering Catch Can | Exedy stage 1 clutch |
JooktheSnooke is offline   Reply With Quote
service, stabilitrak traction controll
