Old 01-19-2016, 12:35 PM   #1
Germy2011
Drives: 2015 Summit White Camaro LS Coupe
Oil Pressure Bar
Hey Guys,
Was messing around in my setting on my dash.
Was watching my oil pressure bar. what does it mean and how do I want to drive my car for the best performance.
Thanks,
Germy2011
Germy2011 is offline   Reply With Quote
Old 01-19-2016, 12:40 PM   #2
The Dutchman
Drives: car
The Dutchman is offline   Reply With Quote
Old 01-19-2016, 01:02 PM   #3
Russell James
Russell James's Avatar
Reading oil pressure in Bars means x barometric pressure.
A general rule of thumb is you want to be above 1 bar at warm idle. About 2 to 4 bars at cruising RPM. Maybe a bit over 4 at high revs.
A car that has a baro sensor and oil pressure sensor can use the ECM to calc the oil pressure in Bars.
A normal pressure reading would do just fine, but some parts of the world like to see their stuff in Bars. Kinda like seeing the fuel in weight instead of volume.
Old 01-19-2016, 01:04 PM   #4
Russell James
...oh yeah, and for best performace you want to drive with the throttle to the floor. Smash the gas as we put it.
Old 01-19-2016, 01:24 PM   #5
Germy2011
Very informative, thank you so much. I will check it out more when I drive home tonight! I am loving my camaro! thanks!
dashboard, oil, pressure
