Old 01-20-2016, 01:02 AM   #1
camarozzzz
Drives: Blue
Gm ground effects rear diffuser
Does anyone know if the square silver parts on the gm rear diffuser come out? I have the arc n2 cat back exhaust with 4.5 inch tips. I think that this size certainly won't fit through the squares - so I might have to remove them if I were to go with this rear. Anyone know what is the max tip size that this diffuser will fit.
Thanks!!
camarozzzz is offline   Reply With Quote
Old 01-20-2016, 09:32 AM   #2
xrivera91
xrivera91's Avatar
Drives: 2015 Camaro 2ss
I believe they are removable. But I could be wrong
xrivera91 is offline   Reply With Quote
Old 01-20-2016, 09:37 AM   #3
ELIC1
Drives: black and silver
yes they will come out i did this to mine... i will tell you with out them it will not look good.. i would buy something that will fit and you can use the bezels.. again its your car and do what you like good luck
ELIC1 is offline   Reply With Quote
Old 01-20-2016, 11:39 AM   #4
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
4 torx head bolts for each bezel. As said above ,won't look good without them. May a after some trimming??
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
Old 01-20-2016, 12:52 PM   #5
camarozzzz
Drives: Blue
What did you use for yours after you took the bezels out?
I am having a very hard time finding a diffuser that works since I have these massive 4.5 inch tips. Yeah you're right without the bezel it won't look great. Need something in there to fill it up.
Thanks for all of the replies !!
Old 01-20-2016, 01:27 PM   #6
ELIC1
[QUOTE=camarozzzz;8853446]What did you use for yours after you took the bezels out?
Thanks for all of the replies !![/QUOTE pm sent..... i think i solved your issue good luck
Old 01-20-2016, 01:56 PM   #7
camarozzzz
Drives: Blue
Thanks a lot !! I think that that is really the best choice I have !!
