Old 01-21-2016, 01:45 PM   #1
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Intake manifold & tb upgrade for Twin Turbo setup worth it?
For the gurus and those with direct experience:
The Context:
My setup is AGP TT w/58/62 Turbos and we are swapping the stock LSA shortblock for a fully built LME motor early next month. The current motor has very nice heads and a BTR Stage III PD cam which we may swap for a Turbo Cam. Power goals are 1050-1100 rwhp reliable.
The Question:
Is there any value in upgrading my stock LS3 and LSA Intake/TB to something else in this process or at a later time?
Target is to make 1100 wheel reliably, made 920 @ 17psi so that shouldn't be an issue but just wondering if there are any reasonable gains moving from the stock LS3/TB combo to something like say an LSXR, LSXRT or sheet metal intake with a setup like mine.
Most EVERYTHING I've read and researched says the LS3/Stock TB approach for anything under 1400 wheel is ideal but I'd love to confirm this with those who know and hopefully substantiated with dyno tests.
Thanks!
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-21-2016, 02:40 PM   #2
Unreal
Drives: 2006 Z06
Unless you want to spend $3k+ on a PMC/etc intake, for little if any gains, there is no point. Stock intakes/tbs are good for 1500+. If you have money to burn go for it, but from a performance stand point, almost a complete waste of money.
Fast intakes don't hold up to boost, and are a downgrade over stock.
Nick
Corvette Z06 -1200ish rwhp
Old 01-21-2016, 11:41 PM   #3
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
My buddy made 886rwhp with twin turbos with the stock intake manifold. The stock flows perfectly well.
Save the money for something else.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 01-22-2016, 08:58 AM   #4
pincushin3819
pincushin3819's Avatar
Drives: 11 AGP TT SS, 14 ECS C7
Sakudog you have a sick build man!
I know your on Fore pumps and Flex Fuel but can't remember if you did a Meth kit? If not Alky Control would be worth the money & after that maybe a 15 inch wheel set up?
Can't wait to see this thing finished!
pincushin3819 is offline   Reply With Quote
Old 01-22-2016, 09:04 AM   #5
Sakudog
Sakudog's Avatar
Thanks! Yes have Alky Control Meth system. As far as a tire I have an 18" ZL1 replica wheel with M&H Racemasters but I might need more tire. TBD!
Sent from my iPhone
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-26-2016, 03:12 PM   #6
Sakudog
Sakudog's Avatar
This is consistent with all of my other research. Thank you for your input.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-27-2016, 09:30 PM   #7
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
I think Sam has done a few of these tests with a NW102 and found almost 0 gain. You gonna bring your car to TX2K or any events coming up?
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 01-27-2016, 09:36 PM   #8
Sakudog
Sakudog's Avatar
Right, AMP said probably not worth the money with my setup. I always triangulate data points, just my style.
TX2K is a maybe because my LME shortblock has to go in before that date and we'd be cutting it very close. The stock rods are like...srsly brah @ 17psi so don't want to buy all that could break if I bend/break a rod making 1100 @ 20psi cause I "wanna go fast".
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-27-2016, 09:45 PM   #9
CyberPredator
50 Shades of Prey
Drives: TT/SS
Im at 1150whp on the stock throttle body and manifold so I say don't waste the money.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 01-27-2016, 10:19 PM   #10
Sakudog
Sakudog's Avatar
Word. Tell me about your turbo and engine setup and the Cam you are running?
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 01-28-2016, 12:06 AM   #11
AGP Turbo
Drives: All things Turbocharged
Stock TB and intake clearly have the airflow capability to support huge power when boosted. But any liquids (meth) injected before the TB don't distribute worth a darn. We're going to do a back to back test on one of our high power cars soon, stock intake vs. carb style w/ elbow. We already know most the meth is going to be back cylinders, but what improvements we can make are yet to be seen. 10.8:1 LSX417
AGP Turbo is offline   Reply With Quote
Old 01-28-2016, 09:38 AM   #12
JANNETTYRACING
JANNETTYRACING's Avatar
You might try the new Nitrous Express direct port Meth system first.
http://www.nitrousexpress.com/15132h...hardlines.html
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-28-2016, 11:29 AM   #13
Unreal
Drives: 2006 Z06
Or use that magic I use.
I actually looked at doing a MSD intake, but $1500 is hard to swallow when my setup works so well.
At least $1500 is less than $2800, but leaning towards just saving up and doing the PMC, even though I bet the MSD would sell easy if I used it for awhile.
Nick
Old 01-28-2016, 12:33 PM   #14
AGP Turbo
Ted.
Maybe I could learn to trust a system like that if I saw a large sampling of people running it for years without any trouble. But past experience says that has too many things we avoid in a meth system. It would be amazing if they have overcome those potential problems. If they wanted to send us one for our test, I'd certainly include the results. (hint hint NX)
