01-21-2016, 02:01 PM | #1 |
Drives: 2015 Camaro SS Join Date: Mar 2015
Straight pipes and CAI bad setup?
2015 SS and I've been straight piped for almost a year and had a CAI on for a few months and I've heard people tell me it's a bad set up with a NA V8 but I've had no issues whatsoever I've actually gained a few hp from the intake obviously and my MPG went up. What's your guys' input?
Thanks Jam on |
01-21-2016, 02:25 PM | #2 |
Bad how? for the environment? Maybe a bit more. For power and badassness where women drop their panties. Nope!
01-21-2016, 02:46 PM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Other than being too loud it is no problem .
OLD GUY FLYING FAST AND LOW
01-21-2016, 05:33 PM | #4 |
By straight pipe, do you mean a muffler delete? There is nothing wrong with that.
01-21-2016, 07:27 PM | #5 |
I was assuming cat delete. I guess it could be muffler too...
01-22-2016, 11:34 AM | #6 |
No Cats and straight pipe could be a little over the top. I think a Cold Air Intake and muffler delete sounds excellent. Don't see how that could be bad for anything..... All personal preference, I suppose.
All the best, Jared Royce 801.545.4215 |
01-23-2016, 11:32 PM | #7 |
I have big mufflers or resonators but I plan on keeping my cats. I actually plan on getting hi flow cats haha
01-24-2016, 04:16 AM | #8 |
Too much is never enough!
It's terrible for you and your car! Your going to catch the MODBUG and never be the same! before you know it you'll be bolting some turbos on it! BE WARNED, take that thing off and return it to stock!
01-24-2016, 03:30 PM | #9 |
Drives: T Join Date: Mar 2015
paycheck trap
