Old 01-23-2016, 11:17 AM   #1
JakeW1990
JakeW1990's Avatar
Drives: 2010 Camaro RS/2SS
Exclamation Boost vs Stock Compression
I'm curious as to how many psi everyone has ran without the need for race gas or a water/meth kit while being on stock compression ratio (LS3/L99). Specifically I'm referring to turbocharged applications, but supercharger guys can chime in as well.
Please state what spark plugs you were using, turbocharged or supercharged (size of turbo or displacement of blower), fuel octane (preferrably the one's that have ran 93 as that's what goes in my tank), and the amount of boost you were tuned for. Dyno numbers would be beneficial as well.
Thanks in advance.
JakeW1990 is offline   Reply With Quote
Old 01-23-2016, 12:07 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
2011 L99 LSA SC, 6 PSI Boost, stock pulleys, 93 pump gas, VVT cam with heads 590+ RWHP NGK plugs 7 heat range
-Don
747 RWHP 794 RWTQ
Old 01-23-2016, 12:45 PM   #3
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
2011 ls3 agp tt kit, turbos are 54/57 JournalBearing --- .63 a/r 800whp (FAST spooling), , 8psi tr6 plugs and 91 octane, currently base agp tune no dyno tune or numbers yet currently working on suspension
Moreair1 is offline   Reply With Quote
Old 01-23-2016, 02:19 PM   #4
cc-rider
Drives: 2010 Camaro SS
Kenne Bell 2.8 on otherwise stock LS3
8 psi
91 octane
NGK TR6 plugs
525 hp
cc-rider is offline   Reply With Quote
Old 01-23-2016, 09:15 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
ZR1 plugs
AGP TT BW 56/61 0.63
91 octane (best here in CO)
9.5psi boost
673rwhp/695ft-lbs
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 01-24-2016, 05:07 AM   #6
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Meth from day one. Sorry I cant help. Subscribed!
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-25-2016, 12:23 AM   #7
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
93 pump 12 psi 750whp
93 Pump+dual nozzle meth 15psi 850whp
93/C16 Mix+dual nozzle meth 15psi 880whp
C16+dual nozzle meth 18psi ???? Coming soon...
Plugs are NGK R5671A-8
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 01-26-2016, 01:57 PM   #8
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
93/meth on 16psi 841rwhp
E85/meth on 16psi 881rwhp
NGK R5671A-8 plugs
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 01-26-2016, 02:25 PM   #9
TRAVIS@SDPC
TRAVIS@SDPC's Avatar
91 + meth 10lbs 693whp
91 + meth 14lbs 792whp
Done on the same tune as it is SD
br7ef or br7efs I can't remember now
TRAVIS@SDPC is offline   Reply With Quote
Old 01-26-2016, 02:32 PM   #10
Unreal
Drives: 2006 Z06
Boost doesn't matter.
Put a cam that bleeds off all sorts of dynamic compression and you can run 20psi on pump.
Or restrict the heads down.
A good set of heads, and cam with SAME power adder and gas may take 5psi and make 800rwhp while just changing a few things, without touching power adder takes 15+psi.
Nick
Corvette Z06 -1200ish rwhp
